REAR CLUSTER PLATE PAINTING.
Postby hamleto » Sun 19.02.2006, 14:26
Hi boys,
I want painting rear cluster plate.
Someone can post any photo about it.
Tank You :D
hamleto
Postby LXADO63 » Thu 23.02.2006, 23:28
Are you referring to the license plate panel that is between the tail lamps? If so, I had mine painted. The panel is easily removed - its attached by 6 (or maybe more) screws accessed from within the trunk (pull back the carpet).
LXADO63
