A Panel Removal
A Panel Removal
Postby Gordon » Sun 09.07.2006, 19:52
My nearside A panel has shifted, and is catching the front edge of the door (common problem I understand). All well and good, I'll remove it, tidy up the fasteners, and refit it I thought!
OK, I can "See" the two bolts into the sill, and the nut which is obscured by the top door hinge, but I cant get any tools anywhere near any of them!
Having owned an Esprit for a few years, I am used to things being difficult to get at, but I'm stumped.
I've not removed the wheelarch liner, as far as I can see, it wont help...
Any "useful" suggestions as to how to undo the three fasteners?
Gordon
Postby delta » Sun 09.07.2006, 22:18
The top bolt is easy when the 2 bottom ones are loose. But to do those you need your normal 1/4 inch top set + a flexible extension rod 20 cm long. Use a 8mm top and a piece of string around the tip, to steer and bend the end of the rod over and around the hinges.
If you have the right tools, it's a 2min. job to take the panel off or put it back on.
Have fun.
Delta.
By the way,: Welcome to the LEC.
delta
Loose bottom hinge - rust?
Postby Gordon » Thu 13.07.2006, 22:37
Yeah! - got it off...
Both the bottom bolts into the rawlnuts had siezed, but after turning them lots of times, the rubber gave up!
I ground down an old 10mm ring spanner to get the top nut undone - it was a bit rounded by someones attempts in the past, but it's off now..
Onto the next problem! - my bottom hinge arm looks loose? - but according to the books, it's welded to the door beam, which in turn is glued to the door skin?!!
I guess I need to get the door panel off at the weekend - not looking forward to what I might find...
Box of rawlnuts and stainless bolts ordered....
Thanks for the welcome - had Lotuses for a few years now, looks like the M100 presents a load of new challanges! - great car though!
Anyone want a Sunbeam Lotus? - I really must thin the collection out a bit.. ;)
Gordon.
Gordon
Spring Clips
Postby Gordon » Sat 15.07.2006, 19:22
Just for the devil of it, I've got both my A-Panels off at the moment, checking for rust :wink:
Can someone send me a picture of the "Spring clips" of which there are 2 (according to the manuals), on the front top edge of the panel.
Neither of my panels have any clips? - just a hole!!
Gordon
Postby Gordon » Wed 11.04.2007, 08:50
Just in case anyone was wondering what I found...
The bottom hinge arm had rotted right through, it was barely hanging onto the door beam.
No repair that I could think of, so a 2nd hand door solved the problem - that one is now full of waxoyl....
Can some kind soul move this thread to doors & windows?
Thanks all.
1990 M100, Calypso Red
2005 Vectra C....
Gordon
