by ratman » Thu 10.08.2006, 07:09
there are differences from car with and without the transparent cover for the license plate? and where can I find one of them?
Thanks!
ratman
by M100 TWO » Thu 10.08.2006, 10:06
South West Lotus Centre had some
www.thelotuscentre.com
M100 TWO
by M100 TWO » Thu 10.08.2006, 10:09
Ps you also will need the gasket
john
M100 TWO
by Rambo » Thu 10.08.2006, 12:23
A tenner at Donny - usual price is abot 26 notes I think
- Don't push me
by ratman » Fri 11.08.2006, 10:16
ok, I have to buy an Elan before!! it is an S2 without it and I like more with.
Do you know if it's reflecting autovelox or not?
I don't want quarrel with the Police!!!
ratman
by muley » Fri 11.08.2006, 11:17
ratman wrote:ok, I have to buy an Elan before!! it is an S2 without it and I like more with.
Ratman,
You're in luck! I'll swap you my perspex covered good condition original for an S2 Plinth.
Whereabouts are you? Let me know when you have the car.
I'm pretty sure it's not reflecting autovelox - it's just a piece of perspex.
by ratman » Fri 11.08.2006, 12:26
if nothin goes wrong, I'll have the car before the end of this month.
I hope that yours is cheaper! ah! I need the seal too!!
ratman
by muley » Fri 11.08.2006, 12:32
Ratman,
Yeah, yeah I'll throw in a new seal (although I normally just use black Sikaflex.)
Keep in touch, I'm out of the country until Sept 8th
by theelanman » Fri 11.08.2006, 13:16
wasnt there a thing about the licence cover not long after it first came out....
the ploice asked lotus to change the design as it inadvertantly reflected the flash back at the new speed cameras and they couldnt see the number to send you your 3 points and the invoice!!!
by Specky » Fri 11.08.2006, 13:30
Not to steal the thread,but...
Are there two types of Perspex cover..
I thought mine was looking a little tiered so I got one from SWL.. and all I got was the clear laminate, not the full cover.. This means I’ll have to separate it from the backing piece..
She is an early Élan though..
by theelanman » Fri 11.08.2006, 14:00
Dave_Speck wrote:Not to steal the thread,but...
what do you mean about the 'full' cover??....
I got one from them and it was a sheet of perspex with a curved lip to the top and with 'smoking' in black to the last inch to the edges....
thought that was it!!!!
can you descibe the two variants.....
by Specky » Fri 11.08.2006, 14:26
theelanman wrote:what do you mean about the 'full' cover??....
mine is like
This.. at first it appears to be all one piece.
The picture below is the SWL one, just the front laminate..
by Rambo » Fri 11.08.2006, 15:14
theelanman wrote:wasnt there a thing about the licence cover not long after it first came out....
Spot on Gareth - it was deemed illegal by the Polis at the time - so that's why I've still got mine !!
I think Hethel stopped putting the on the M100 because of this and that's why you don't see too many with them on. Personally, I think it looks better finished with the perspex cover
Mark
- Don't push me
by GeoffSmith » Fri 11.08.2006, 15:46
Rambo wrote:Personally, I think it looks better finished with the perspex cover
Or what about some of
this?
- Kitty Fiddler
by Rambo » Fri 11.08.2006, 16:58
geoffsmith wrote:Rambo wrote:Personally, I think it looks better finished with the perspex cover
this?
"However a local Policeman said "It works well, in fact it is the best I have seen, but if I see it on a car I am going to stop them"
And what are that chances of that then ?? None and f---all
- Don't push me
by muley » Fri 11.08.2006, 20:24
Rambo wrote:geoffsmith wrote:Rambo wrote:Personally, I think it looks better finished with the perspex cover
this?
"However a local Policeman said "It works well, in fact it is the best I have seen, but if I see it on a car I am going to stop them" And what are that chances of that then ?? None and f---all
ROFL. But Chris t. did get stopped by the BiB in the pourimg rain because his cover had steamed up ...
by Dovey » Fri 11.08.2006, 20:50
Yeah, the cover looks cool! Loads dont have them on but I think they should do.
Stupid legislation, gatso's and the local bobby aint ruining the look of my car
Never buy anything that was built on a Friday
Dovey
by surfboardfiller » Wed 23.08.2006, 11:17
"what do you mean about the 'full' cover??....
can you descibe the two variants....."
I have only seen one S1 Cover, the two on this thread are the same only one has the GRP housing included with the bent sheet of perspex/acrylic attached.
I used an Automotive silicone sealant to stick the two together and number plate mounting tape to fit the unit to the car before screwing it on.
you may need to loosen the bumper to fit the unit.
The S1 has holes in the transom pannel to prevent the unit from misting, this may be worth considering if you fit this to an S2.
I'm still looking for a number plate that doesn't melt in this little 'greenhouse'.
Cheers,
surfboardfiller
by theelanman » Wed 23.08.2006, 12:59
it would appear that dave_speck has a different version to the one SWL have .....I must admitt Ive never seen one like it...it looks flat......
check out the link to ebay and have a look....its a new one on me
cheers
G
by Monty » Wed 23.08.2006, 13:43
later model SE`s and S2`s have a different black plinth
- Chunder King!
