Seals repair
Seals repair
Postby Marc33 » Tue 12.12.2006, 01:50
My seals around the windows was in very bad condition.I buy a soft adesive rubber and i repair the seals.
I think the work looks good.
You can see at: http://lotuselan88.altervista.org
Bye! M.
Marc33
Postby Sy V » Tue 12.12.2006, 09:17
Marc
Looks very nice, but my concern would be what happens when the hood is folded.
That is why the seals are separated above the window (above the red seat stripe in your last picture).
Postby Marc33 » Tue 12.12.2006, 10:55
Sy V wrote:Marc
Hi.It is no problem,because the rubber is very soft and the adesive is very strong.But i'll be sure in the next summer! :) :)
M.
Marc33
Postby GeoffSmith » Tue 12.12.2006, 13:20
I suppose you could try cutting the strip in line with the original break.
Could you let us know where you got it from Marc, as there is a Welsh S2 with an indoor swimming pool which may benefit.
Geoff
Postby mikeydude » Wed 20.12.2006, 18:34
marc33 I used a simliar material on my a post seals....but it broke up in less than a year.
It was just too thin a coating.
I could do with knowing what the material was that you used.
I have seen some advertised (sold as sheets though not a strip)
Iwill try to remember where it was
mikeydude
