Moderators: theelanman, GeoffSmith, Sy V, Elanlover, muley, Enright, algirdas, nitroman, clemo, Specky, dapinky, Dave Eds, Nige, DaveT
by C3LOS » Sat 18.03.2017, 18:40
Finally got round to sorting my heat shields out.
The bottom 2 bolts were an absolute pig, but after lots of swearing, scratches on my hands and forearms, plus a few different tools.....they came out!!!
Now time to make them look like new again.
C3LOS
- Tinkerer
by Saltire » Sat 18.03.2017, 19:02
As a matter of interest, what do you plan to do by way of refinishing?
S2 no 512, BRG/LRG, magnolia interior, last of four UK S2 to this spec
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Sutherland
by C3LOS » Sun 19.03.2017, 22:35
A bit of VHT paint (7 thin layers) and a few hours in the kitchen oven and there we go...
Bitch of a job getting it back on...ended up making a stud for the side fixing next to the front engine mount as I just could not locate the original bolt. Theses original engineers need shooting!
Anyway, happy look to my engine bay with a few clip and clamp changes, hose upgrades and corrugated tubing...what you you think?
C3LOS
- Tinkerer
by Saltire » Sun 19.03.2017, 23:50
Much improved, and a great finish on the heat shield - I'd wondered about VHT. Also considered powder coating, but felt it probably wouldn't stand the temperature. Mind you, I'm closed loop, so I'll have to get the O2 sensor out first
by dapinky » Mon 20.03.2017, 11:13
Saltire wrote:Much improved, and a great finish on the heat shield - I'd wondered about VHT. Also considered powder coating, but felt it probably wouldn't stand the temperature. Mind you, I'm closed loop, so I'll have to get the O2 sensor out first
Jonathan,
I used VHT (Halfords Aluminium) about 9 years ago and it still looks okay...
.... and there is no need to remove the O2 sensor, just unplug the wiring on the OS inner wing and lift the shield over it.
by Saltire » Mon 20.03.2017, 15:02
dapinky wrote:.... and there is no need to remove the O2 sensor, just unplug the wiring on the OS inner wing and lift the shield over it.
Thanks, Dave - easy when you know how. As the meerkat said: "Simples!!"
by C3LOS » Mon 20.03.2017, 22:12
Thanks for your comments on how it looks...I am v happy. Time will tell if it's durable....as for your car the problem won't be the O2 sensor, trust me...it will be the side bolt next to the front engine mount.
I ended up using a 10mm straight ratchet, lots of swearing and huge amount of patience.
Good luck
C3LOS
- Tinkerer
by roy666 » Sat 13.05.2017, 15:33
Guys - this looks great. It urged me to sort out my heat shield, something was rattling but I could'nt tell which part. I finally got it up on a ramp and found that the bottom part of the shield was poprivited on to a bottom peice of shield. Both the bolts for the bottom part had been sheared through at some stage and still in the exhaust down pipe. How on earth do I get those out?
roy666
by roy666 » Sat 13.05.2017, 15:35
Its in a bit of state. What would you say is the best option for a repair and ccoating?
roy666
by dapinky » Sat 13.05.2017, 16:11
When I did mine (about 9 years ago!) I just used a wire brush in an angle grinder to clean them up, then sprayed with Halfords VHT paint in an aluminium colour.
If I were doing them today, I'd either dip them in a 10% phosphoric acid bath or sand blast them first, then use the same paint.
by roy666 » Sat 13.05.2017, 16:25
Ok.... what do you think this is. A loose bit of metal behind the exhaust heat shield, sheared off. serving no point now; I 'll drag it out. Is it dangerous to drive the car without the heat shield; just be easy on the revs i assume. And I have quite a bit of oil on the air inlet to the turbo. is that normal?
roy666
by C3LOS » Sat 13.05.2017, 23:14
Glad you are getting your heatsheilds done...makes a big impact in the engine bay when its done.
I painted mine with Halfords VHT paint...gave it a good wire brushing and cleaned them with white spirit before approx 6 very light films of the VHT.. then baked them in my oven for around 2 hours(wife only found out when I posted pics of them in there on Facebook.
I also noticed the manifold heatsheild was still on in the pic. Would suggest doing that to..easy to remove..just need to take the dipstick bracket off.
As for the extra bit of metal, looks odd...would just bin it. As for driving without the shield, that's up to you but I wouldn't.
Would love to see the final result when all is done
Good luck
Carl
C3LOS
- Tinkerer
by roy666 » Sun 14.05.2017, 10:16
Thanks for the advice C.. and i will put some pics up. What is the little bracket with the 2 x bolts in your 2nd photo? Where does that sit,.. i don't have one of those anywhere on my engine? M
roy666
by roy666 » Sun 14.05.2017, 12:13
C - ok, realise what the bracket is now.. my bad. Its the dip stick bracket, but I can't shift the bolts.. if i crack on I'm bound to shear them. How did you get yours out?
roy666
by C3LOS » Sun 14.05.2017, 22:33
To be honest the 2 bracket bolts came off after a bit of persuasion.
Can I suggest a dose of WD40 for 24 hours on the bolts..tried it on my seats and front splitter lip and seems to help to loosen them. Just be careful where it goes as you are near the exhaust manifold. Either that or a bit of warmth also helps...
Does anyone else on LEC have any other ideas?
Good luck
Carl
C3LOS
- Tinkerer
by Grampy » Fri 28.07.2017, 09:26
Best of luck getting the bolts out. When I did my rebuild I had to drill out nearly every bolt. Complete pig of a job
u
Lotus Elan SE
lotus Elise S1
Golf R32
Audi A4 mile cruncher
Grampy
by roy666 » Tue 24.10.2017, 22:22
Hi Guys - I thought I would finish this of... and I also have a little issue. The hi-temp coating for the heat shields came up good, it was really worthwhile.
However, when the car went for a head gasket change very recently, the technician (did not want to be called mechanic!) didn’t get around to putting the strip of heat shield that fits behind the turbo back on the engine. I was so exasperated and just wanted to get the car back that I said don’t bother, I’ll stick it back on. Well, now I think I’m missing a mounting, or some bracket or other, that goes underneath the strip, where the hole for the turbo heat shield bolts through. I just can’t recall how/what that screws into. What am I missing? Mike
roy666
by par » Tue 24.10.2017, 23:44
Looks like you have a whole other piece of heatshield missing, a long strip that fastens to the manifold which the turbo heatshield then connects to.
par
by roy666 » Wed 25.10.2017, 07:15
Thanks - what size bolts are the 2 that bolt direct into the engine block? And the bolt that connects the turbo shield to the engine shield, that just bolts through to the captive nut on the back of the engine shield. There's nothing else that supports this bit?... is that right? M
roy666
