by Richmmm » Sat 18.03.2023, 22:30
After having the car laid up over the winter, it has just gone into the garage for the turbo refurbishment.
Midland turbos in Nottingham turned the unit round very quickly and now i am sourcing gaskets and parts to reassemble the turbo onto the car. I have swapped the exhaust manifold, as mine was suffering from quite a few cracks and have mangaed to source a replaceemnt via ebay.
The exhaust manifold to Turbo studs were damaged in the removal process so need replacing, However, they are not available when i put the part mumber into the list on SJ sports cars web site.
Does anyone know the specification of these studs, as a quick google search brings up lots?
Rich
Richmmm
by TorqueHorse » Sun 19.03.2023, 03:42
Hey Rich,
I just grabbed these photos real quick, so hopefully they can point you in the right direction. Note the two different thread pitches.
with the locking nut
overall length
pretty sure this is the side that goes in the exhaust manifold
pretty sure this is the side that goes through the turbo
overall diameter
'90 FED M100 -mid restoChassis
Exterior FrSus RrSus Engine Trans
Wheels Steering
Brakes Cooling Fuel Ventilation Exhaust
Interior
by muley » Sun 19.03.2023, 08:39
FWIW, I replaced mine with stainless steel set screws
1995 Palacio S2 no 507 : 1991 Aqua Blue SE Honda Jazz 1.3 2006 Ford Focus 2.0 Duratech
by Richmmm » Sun 19.03.2023, 10:18
Thanks for the brilliant reply, just the info I need.
Rich
Richmmm
