missys turbo has went pop.
Postby stevo » Wed 27.06.2007, 21:49
missys turbo has went pop. then lots of grinding and expencive noisys and smoke. bum. it happen on the way up to archies at the weekend but i managed to struggle on n/a style by taking the plenem hose off and bypassing the oil feed.
anyhoo i need a new turbo, has anyone got one and what costs are involved in upgradeing?
stevo
Postby Doug » Wed 27.06.2007, 23:20
project creep upgrade begins :-D
Postby Monty » Wed 27.06.2007, 23:28
Re: missys turbo has went pop.
Postby Ekapol » Thu 28.06.2007, 06:42
stevo wrote:anyhoo i need a new turbo, has anyone got one and what costs are involved in upgradeing?
Mine has just arrived today. :-D
Can't be a better time for you for an UPGRADE
You will need the one for T25 config with adapter plate (contact "Crambury RS"), stainless steel hoses, and etc.
Ekapol
Postby rip » Thu 28.06.2007, 08:10
I have heard that Turbo Technics are useful. Never dealt with them myself though.
Postby Monty » Thu 28.06.2007, 14:09
IIRC Sy used them for his turbo work
www.turbotechnics.com/docs/index.htm
Postby Doug » Thu 28.06.2007, 18:01
Ekapol wrote:Mine has just arrived today. :-D
Is there something we need to know about, Ekapol?? :poke:
Postby Sy V » Fri 29.06.2007, 05:23
No Jay (but you're close) I used Turbo Dynamics:
http://www.turbodynamics.co.uk/contact.htm
Ask for Mano Zevgolis.
Postby Ekapol » Fri 29.06.2007, 06:37
I've been cooking up this evil plan for some time now.
This Garrett GT2560R will spool much faster than what we have, full boost at ~ 1,500 rpm faster, 1,000 rpm quicker than the T-25, or so, and it's a bolt-on item, easy to convert back to the original setup, good for up to 320 HP, will make T25 kinda obsolete in comparison :-D
Figure Stevo might be benefited for switching to one of this instead :P
Ekapol
Postby Russc » Fri 29.06.2007, 09:48
Nice :) and a pretty decent price if anyone over here wants one
Including shipping to the UK £549 !!!
Russc
Postby ailwyn » Fri 29.06.2007, 13:30
Ekapol wrote:and it's a bolt-on item
Define bolt on. Straight swap or change injectors, and ECU type bolt on?
If it's a straight swap... sign me up :-D however somehow I doubt it will be that easy :evil:
A.
Postby Monty » Fri 29.06.2007, 15:48
Sy V wrote:No Jay (but you're close) I used Turbo Dynamics:
LOL :roll:
Thanks for the link, as i`ve saved that for future reference :-D
Postby Ekapol » Fri 29.06.2007, 17:59
Let me find out and will keep you posted. Don't think you need to change all those unless you want to increase boost, etc. :)
Ekapol
Postby Dico » Sat 30.06.2007, 21:47
Sorry Stevo been away, in answer to your text, no I no longer have one for sale.
Get your name on Ailwyns group buy :twisted:
1. Ailwyn
2. Dico
:lol:
Postby GeoffSmith » Sat 30.06.2007, 22:42
Good old Ailwyn. Just watch out for the group buy hijackers. :wink:
Postby F1 LOTUS » Sat 30.06.2007, 23:01
Ekapol wrote:
This Garrett GT2560R will spool much faster than what we have, full boost at ~ 1,500 rpm faster, 1,000 rpm quicker than the T-25, or so, and it's a bolt-on item, easy to convert back to the original setup, :P
I don't think so...
Check Houdinis' thread.
I believe you'll need custom hoses in and out of the compressor, and an adaptor plate for the exhaust manifold, custom 'stiffy' and, custom oil and water feed / return pipes. Also, I 'think' the integral wastegate actuator will need a custom bracket for the orientation? I don't know if ESM's chip would be the only 'boost control' device we'd need; I guess it depends upon how well the wastegate flows???
I too must confess to looking into this [Garrett ball-bearing] route, using a custom designed cast exhaust manifold that would eliminate the pre-cat and a simple elbow to align to the downpipe. Motivation - I don't fancy refitting the original turbo with +130k miles and a cracked / welded manifold. I've done some preliminary work, and Houdini was offering a huge amount of help further down the line, but lately I've not had much time to progress with this project...
Taking a real WAG at the cost for a bolt-on conversion...I think we'd have to be talking $1200-$1500? (This assumes a good group-buy deal on the turbos).
Who would be interested at this level?
F1 LOTUS
Postby Dico » Sun 01.07.2007, 10:21
F1 LOTUS wrote:Taking a real WAG at the cost for a bolt-on conversion...I think we'd have to be talking $1200-$1500? (This assumes a good group-buy deal on the turbos).
I feel the need for speed :P
1. Dico
Postby ailwyn » Sun 01.07.2007, 16:55
F1 LOTUS wrote:I think we'd have to be talking $1200-$1500? Who would be interested at this level?
I'd certainly be open minded about it
1. Dico
2. Ailwyn
Postby Dico » Sun 01.07.2007, 17:30
Good man
I'm not the only crazy one then :P
Postby Paul.P » Sun 01.07.2007, 19:06
Dico wrote:I'm not the only crazy one then :P
Wealthy one you mean !
