by GeoffSmith » Sun 24.02.2008, 23:18
Monty wrote::smt017
Me too!
Alarm sorted for now - Wiki now updated to include S2 fuse positions!
- Kitty Fiddler
by Specky » Sun 24.02.2008, 23:47
All I need to do now is disable the alarm
TAXI....... I'll get me coat...
by Monty » Mon 25.02.2008, 00:10
Specky wrote:All I need to do now is disable the alarm
Was that suppose to be Manc joke lol
I`m good but not that good
- Chunder King!
by GeoffSmith » Mon 25.02.2008, 00:15
I must be tired. I'm completely lost. More bizarre than the Non-Members area.
- Kitty Fiddler
by GeoffSmith » Fri 29.02.2008, 23:05
And everything is back on again...... two months without a drive was too much to resist so I went and picked her up from a concert, hood down of course.
It's good to have it on the road again.
- Kitty Fiddler
by Specky » Sat 01.03.2008, 02:48
Strange question...
as I've never seen the Porting on the waste gate, I think I read to rework to 4mm somewhere...
why that size...
Also can it be reamed...
Bloody engine-ears...sorry..
by Paul.P » Sat 01.03.2008, 09:51
Specky wrote:as I've never seen the Porting on the waste gate, I think I read to rework to 4mm somewhere...
why that size...
Also can it be reamed... TTFN
Dave, presume you mean 4mm oversize. The reason we port to 20mm is because ( by trial & error ) we found it works, & that particular grindstone
is readily available from B&Q. As for the reaming, do you mean in a lathe, cause you have difficulties holding the part, although i'm sure some clever sod would do it. It took me 10mins with grindstone, although i know others took a lot longer, but i do have a very good drill.
by GeoffSmith » Sat 01.03.2008, 11:35
As Paul says, it was tried and it worked. It could be reamed, but does it need precision (no), does everyone have / have access to one (no) or is B&Q an nationwide source of the right sized tool (yep).
- Kitty Fiddler
by Specky » Sat 01.03.2008, 13:37
Cheers,
Didn't know if you had used a bernoulli's style theory or gone a different route..
by GeoffSmith » Sat 01.03.2008, 13:59
And the good news is...... no more boost creep, even with the boost turned down to gas mark I.
What a lovely day it is.
- Kitty Fiddler
by Candles » Tue 15.04.2008, 10:54
I'm having a minor porting disaster:
I wanted to port the wastegate, but couldn't be arsed to remove the turbo. So, armed with Dremel and right-angled head, at it I went. Grinding was going well until the chuck on the Dremel came loose and deposited the grinding wheel inside the wastegate, out of sight. Not easily defeated, I thought I'd try a magnet: No luck. Hoover: No luck. Finger: No way.
Anyway, I took off the turbo, spilt coolant everywhere and finally caught a glimpse of it right down inside the exhaust manifold. I was worried it might migrate to an exhaust valve or something, but there is no danger of this. Eventually with much swearing and using the magnetic driver bit from a cordless drill, I got it out! Now I have to reassemble everything. I might as well have ported the 'gate on the bench or I could have just ported my spare turbo, then swapped them!
The winter project continues..........
Candles.
Candles
by GeoffSmith » Tue 15.04.2008, 12:54
Sure you're not a gynaecologist?
There is a hell of a lot of crap comes off when you're grinding. You're better off having it apart so you can remove all traces of abrasive wheel that found there way into the turbo housing.
- Kitty Fiddler
by ailwyn » Tue 15.04.2008, 15:55
Geoff
Any tips on separating the turbine housing from the centre cartridge?
A.
- Forum Member
by GeoffSmith » Tue 15.04.2008, 17:40
Carefully! Mine had sealant between the two so I very carefully prised them apart.
- Kitty Fiddler
by ailwyn » Tue 15.04.2008, 21:34
Any chance of being more descriptive?
I seem to be suffering from the Lotus/Isuzu Krypton Factor challenge, yet again (AKA the chicken and the egg).
I have removed all bar one of the bolts that attach the turbine housing to the main body, but the last one catches on a moulding on the cartridge and therefore I can't release the plate that secures the turbine housing to the cartridge. The join is also probably sealed (the compressor housing was).
Any tips gratefully received.
A.
- Forum Member
by Candles » Tue 15.04.2008, 22:34
I just shoved the hoover into the end. All the flow is outwards anyway, so no crap can get anywhere it can do any harm.
Candles
by Monty » Tue 15.04.2008, 23:09
ailwyn wrote:Any chance of being more descriptive?
A.
Ailwyn,
Do you mean the Alloy compressor housing?
Or are you talking about splitting the Turbo, ie seperating the cartridge as you would for a refurb as i had trouble removing one of the bolts when i attempted to refurb my spare IIRC i used an openend spanner and just kept turning the bolt and it eventually i got it out. The only thing is you`ll need to use heat to seperate the cartridge, i didn`t know this and thought a tap with the hammer and it will come loose, ended up cracking the cartridge
- Chunder King!
by ailwyn » Wed 16.04.2008, 08:43
Monty,
It's the turbine (exhaust) side that I'm trying to separate.
The compressor side came of fairly easily with gentle persuasion.
The cartridge fits inside the turbine housing and then has 2 plates bolted on top. I have managed to remove all bar one of the bolts (and 1 of the plates) but the bolt that's left is hitting a moulding on the cartridge and I am unable to undo it enough for it to drop out and release the last plate.
I have tried using a hammer to provide as much persuasion as I dare, which is not a huge amount, so heat may be the answer.
I might just end up cutting the last bolt, although that's not really what I want to do.
A.
- Forum Member
by Monty » Wed 16.04.2008, 10:54
I`m sure i managed to get that bolt out
maybe cutting the bolt might be the way to go. There`s a write up
Here and this guy actually replaces those bolts with a shorter ones.
After damaging my spare turbo
(which is now useless
) did a search on the net and found that RobieTheRobot used a propane torch to seperate them
http://www.robietherobot.com/storm/geo_ ... _turbo.htm
- Chunder King!
