upgraded turbos, what have you all done?
Postby lotusgirlmarie » Sun 01.06.2008, 23:31
I dont think anyone....... I take that back, Houdini did a sort of write up on the install. Ekapol also has some pics on the stripey thread. Cost is really dependent on where you source your parts from. It can get alittle pricey depending on this fact. IMHO though it was well worth the effort in the end. If anyone really, and I do mean REALLY wants to go down this route I can look into making up some downpipes and the coolant and oil feed lines to ease installation. Perhaps even a full install kit with the turbo outlet pipe and the compressor intake and outlets. With these and the turbo + adapter plate its almost a bolt on install.
lotusgirlmarie
Goddess
Postby ailwyn » Sun 01.06.2008, 23:54
lotusgirlmarie wrote:Perhaps even a full install kit with the turbo outlet pipe and the compressor intake and outlets. With these and the turbo + adapter plate its almost a bolt on install.
lotusgirlmarie wrote:If anyone really, and I do mean REALLY wants to go down this route
Where do I send the money?? - Committed enough?
This would be great right now as I currently have my S2 in it's non-native N/A configuration while I strip it from the block to the peco and refurb the lot, if I can upgrade the turbo while I'm at it then :-D
Postby Monty » Mon 02.06.2008, 10:18
lotusgirlmarie wrote:I can look into making up some downpipes and the coolant and oil feed lines to ease installation. Perhaps even a full install kit with the turbo outlet pipe and the compressor intake and outlets. With these and the turbo + adapter plate its almost a bolt on install.
Marie,
Your a Star, i`ve been thinking about the Turbo upgrade for a while and would like the bits so i can do this in the near future.
You can count me in for the part kit :wink:
Downpipe (from the back of the Turbo to the flange joint)
Oil & water lines
Adaptor plate (with bolts)
I may even go for the Full kit depending on the price of the Turbo
Just wondering is it easy enough to get the Injectors, 3 bar Map sensor and the Turbo on this side of the Pond :?
Postby MattDon » Mon 02.06.2008, 10:31
id also be very interested, funds dependent. ive been looking into upgrading the turbo for a while but all the companies have stated that it wouldnt be cost effective, so this seens like a way to achieve what id like to without going to that length. my main aim was to aviod having to go down the haltech route, while maximising the performance and improving reliability.
MattDon
Postby ailwyn » Mon 02.06.2008, 12:28
Turbo Upgrade Interest
1. Ailwyn (x2 maybe)
2. Monty
3. MattDon
Postby theelanman » Mon 02.06.2008, 13:53
I too am interested....
I was thinking of having mine rebuilt.....
so depending on the cost of the bits....a new
GT2560R...is £490.50 + VAT........
I'll not add my name to the list 'just' yet :wink:
Postby Nige » Mon 02.06.2008, 15:21
As I've already bought an adaptor plate and have been working this one through for some time I've added myself to the list :-D . In fact I PM'd LGM last night, before Matt's post and her response, asking her for some specific details so I could take this planning further.
2. Monty
3. MattDon
4. Nige
Back in Blighty
Nige
Postby lotusgirlmarie » Tue 03.06.2008, 13:24
It was because of Nige that I decided to do this little inquire.
2 kits Im looking at, just for clarification.
#1 downpipe (turbo to exhaust flangepoint)
OIl feed line to turbo ( outlet is modified from stock piece)
2 coolant lines and addapter fittings
#2 all above +
Turbo inlet in either 2.25" or 3" (your choice)
Turbo compressor outlet in 2"
Turbo compressor discharch to intercooler pipe and silicone connectors
Turbo heat sheild
with #2 all you will need to source is the turbo and adapter plate. I leave the intake pipe out as there are many different options as to what you can do such as there are too many options as to finished product.
lotusgirlmarie
Goddess
Postby Monty » Tue 03.06.2008, 16:20
Marie, you`ll have to bare with me, as i`m not sure which part is which :? (any photo`s to help identify some of the parts)
Is this the pipe from the filter to turbo or some kind of adaptor plate? as i`ve already got the TopEnd pipes.
is this another adaptor to go to the lower pipe to intercooler?
will the stock one not fit to the new turbo?
Turbo heat shield
can the stock sheild be bodged to fit?
If you can come up with a rough guide price for each kit that would be great :wink:
Postby lotusgirlmarie » Tue 03.06.2008, 17:47
Monty wrote:Marie, you'll have to bare with me, as i'm not sure which part is which :? (any photo's to help identify some of the parts)
Is this the pipe from the filter to turbo or some kind of adaptor plate? as i've already got the TopEnd pipes.
The Garrett turbo has bolt on fittings to the turbos compressor housing. The Top End pipes are designed for the IHI's 1'3/4" inlet. The new turbo has the option of two inlet sizes which are purchased separately from the actual turbo.
Yep, kinda the turbo needs an outlet flange to allow a hose to be attached. the IHI's outlet is also 1 3/4". Garrett doesn't make an outlet this small.
Nope.
Turbo heat shield
I tried. Its a really tight fit and you have to cut away alot of the stock housing then mounting it becomes an issue.
Working on it.
lotusgirlmarie
Goddess
Postby lotusgirlmarie » Tue 03.06.2008, 17:58
piccies
lotusgirlmarie
Goddess
Postby Monty » Tue 03.06.2008, 18:29
Thanks Marie
Had a feeling that that the Garrate Turbo needed some type of bolt on adaptor, just wanted to make sure as now i can decide what parts are essential :wink:
BTW Marie are you still using an O2 sensor? as i don`t know if to fit one to my SE :?
Postby lotusgirlmarie » Tue 03.06.2008, 19:07
No worries. Yep on the O2. I have a bung welded in for it as all Fed cars require one.
Pretty much all of the fittings are required for the install. I went the stainless braided route with all of the hoses for that added bit of security.
lotusgirlmarie
Goddess
Postby F1 LOTUS » Tue 03.06.2008, 19:19
Hi Marie - bet you're beginning to regret this already? :lol:
Just to make sure life won't be to easy for you...I am interested in doing this too except I'd want to use the GT2554 (GT2560's li'l bro') - the turbine is identical but the compressor is different so I'd need to figure out my own air pipes, and possibly the wastegate actuator would need a custom bracket to orient it correctly?
If this proves as popular as I think it will be, we could be in a good position for a group buy on the Turbo's - Houdini might have a lead on a distributor willing to 'deal'? :)
F1 LOTUS
Postby lotusgirlmarie » Tue 03.06.2008, 19:36
the wasegate is easy enough to orient the right way without an additional brackets. your still going to need the compressor outlet adapter, oil and coolant lines the same outlet to intercooler pipe and downpipe. Its pretty much the same deal just sans the compressor inlet. I was looking at this same turbo for awhile then came to the conclusion that it wouldn't allow me the upgrade ability of the GT2560R Its a good turbo but similar flow to the stock IHI
Oh and to your first question....... its a bit early but...
lotusgirlmarie
Goddess
Postby Paul.P » Tue 03.06.2008, 21:53
Would be very interested in a full kit.
2. Monty
3. MattDon
4. Nige
5. Paul.P
Postby F1 LOTUS » Tue 03.06.2008, 22:07
Paul.P wrote:Would be very interested in a full kit.
2. Monty
3. MattDon
4. Nige
5. Paul.P
6. F1 LOTUS
Re: GT2554 - I'm banking on the better response and have no intention of going beyond the stock ECU's capability - totally understand your :twisted: choice :D
Re: Wastegate issue - probably something I've mis-recalled from conversations with Houdini...about a different turbo?...for a different car?...from a land that time forgot no doubt :P
F1 LOTUS
Postby Nige » Tue 03.06.2008, 22:21
Wow! This one seems to have taken off. Firstly and above all else a huge thanks to Marie for even considering this. My enquiry was for info so I could see how I might do something similar to Marie's install here in UK but if the possibility of a run of kits exists then I'm in and the option to explore a group buy on the turbos would be the icing on the cake. Personally I'd be in for the most complete set as possible to make this as bolt on as possible. I've already got the exhaust manifold to T25 adaptor plate (well it's on it's way) and also have a custom intercooler with increased capacity and all ally (including end tanks) construction. It will require a bit of modding of the GRP ducting but other than that should be a straight swap.
Back in Blighty
Nige
Postby F1 LOTUS » Wed 04.06.2008, 00:29
Ekapol wrote:I know a girl that can install it in my car port in a day, about the same amount of time I left my mouth wide open :shock: still I can't believe that :smt017
This probably helped :D
F1 LOTUS
Postby nitroman » Wed 04.06.2008, 08:42
F1 LOTUS wrote:Re: GT2554 - I'm banking on the better response and have no intention of going beyond the stock ECU's capability - totally understand your :twisted: choice :D
The aftermarket turbo packages for Mazda MX5s (http://www.flyinmiata.com) say:
The standard turbocharger is the GT2560R. This is our favorite all-around turbo, providing good power potential with good spoolup. A smaller GT2554R is also available for those who make response their highest priority.
nitroman
