vi11ain wrote: I've just taken the car for a test run with ElanScan and (unfortunately) managed to provoke fuel cut a couple of times due to boost creep. I can see that it's regularly boosting to around 0.75 bar, which ought to be impossible anyway, but going at it harder makes the boost inexorably climb above 0.9 with the inevitable result.
The thing that's puzzling me at the moment is that the wastegate duty cycle never seems to rise above 25% - in fact, at around 580 seconds into the scan the duty cycle is 0% even though the boost is over 0.9 bar! Can anyone shed any light on this, or am I misunderstanding the data in some way?
I'm attaching the zipped ElanScan file so you can see what I mean.....
Over the weekend I plan to disengage the actuator to see what happens then.
Ben
vi11ain wrote:While in the shower this morning (all my best thinking is done there!) I realised that 0% wastegate actuator duty indicates that the ECU is trying to REDUCE the boost as it's allowing the full bost pressure to bear on the actuator, thus opening the wastegate. Activity above 0% on the BCFV indicates that the ECU is trying to increase boost above 0.4 bar (or thereabouts).
vi11ain wrote:I've just tried running the car with the wastgate actuator disconnected, so the wastegate is free to open fully. The result is that the maximum boost I was able to achieve was about 0.6 bar, although I'm going to do another run with ElanScan to be sure. This seems to prove that the port is adequate when the wastegate is wide open....
The question now is how far does the actuator actually move to open the wastegate when it's functioning correctly? I'm going to carry out a pressure test on the actuator to see how far my one moves, but I have no basis for comparison. Unfortunately the Service Guide only mentions that it should initially have moved 2mm when it has attained a pressure of between 9.8 & 10.2 psi.
Ben
vi11ain wrote:I don't think that the MAP sensor is suspect because it is providing the readings that show the overboost on Elanscan and thus cause the ECU to cut the fuel giving message 31.
GeoffSmith wrote:vi11ain wrote:I don't think that the MAP sensor is suspect because it is providing the readings that show the overboost on Elanscan and thus cause the ECU to cut the fuel giving message 31.
Makes sense to me.
Makes sense to me.
Paul.P wrote:Ben, be careful if your gonna grind the whole any larger, the flap only covers 25mm & you should already have 20mm, so that only leaves 2.5mm either side, not a lot to get a seal on, especially if your gonna make it smaller ?
vi11ain wrote:I managed to remove the wastegate downpipe (so much easier now it's been recently removed!!) and I could just about get to the wastegate port for some more grinding, although it wasn't very easy!!
Anyway, to avoid too many of the grisly details, I think I managed to remove about 1 - 1.5mm material on the diameter of the port. I also smoothed out the interior of the port so the gas could flow around the corner more easily - there were a couple of sharp corners before that took a bit of removing. I finished putting all the heat shields back in place this afternoon and took it for a test run with Elanscan - result.....
No more boost creep or overboost!!!! Hurrah!![]()
I can't really express how happy I was to see the boost gauge stop rise to around 0.6 bar and just stay there, back under the control of the ECU!! It's really great to be able to drive using full throttle again after two years of enforced 1/2 throttle - not to mention the past couple of months of fiddling around with the turbo and grinding ports etc! I've finally got my old car back - but with a better exhaust and PCE.![]()
Elanscan confirms that the max boost was 0.66 bar - nearly perfect!
As a further bonus I managed to remove the pesky O2 sensor blanking plug from the manifold after the test run, so I will be able to fit a sensor and hopefully increase my mpg once the appropriate Everest chip has been fitted
So, tomorrow I'm going to celebrate by fitting the new Hispec brakes - I'm hoping for no "complications" this time!!![]()
Ben
PS It was great to meet a few of you at Donington today - I managed to resist spending loads of money at the show and it was good to see so many Lotii in one spot!
esprit888 wrote:Great news Ben ! But scary to me as i am going down this same road. So the opening size is critical to within 1mm to prevent creep & OB ?
Blue_Bullet wrote:Maybe a silly question but.....
Did you do all that with the wastgate still in the car?
or are you just undoing a nut and bolt with that 14.4 Volt Drill?
