by GeoffSmith » Fri 17.08.2007, 19:45
WWW - Wiki's Waiting Wright
- Kitty Fiddler
by Russc » Mon 20.08.2007, 13:57
Russc
by paulwatkins » Mon 20.08.2007, 14:06
Russ,
here's an excerpt from the service manual for removing the turbo.
I know it makes it sound easy, but some of the nuts and bolts are a right bugger to get to. But basically, you just follow the procedure and then use the pics I posted on page 2 of this thread as a guide to opening up the wastegate.
When you get the turbo off, its obvious what you need to do.
paulwatkins
by paulwatkins » Mon 20.08.2007, 18:43
Does this help?
Unless you've recently installed an oxygen sensor, an SE doesn't have one, so you've completed step 1 already!
paulwatkins
by Russc » Mon 20.08.2007, 20:55
Russc
by Tim A » Sat 25.08.2007, 12:22
I think my new Elan has a Peco system.
At wide throttle openings I get a high pitched whistle / squeal... At which point I back off or change up....Is this boost creep ? I have not reached fuel cut off because the whistle / squeal sounds expensive....and I immediately come off the gas pedal..
So if I take my Elan to a lotus man and ask him to "port my wastegate" what would a fair quote be ?
I dont have the time to do it myself and I am keen to get the best from the car.
Thanks.
-Tim
Tim A
by GeoffSmith » Sat 25.08.2007, 12:50
Sorry Tim. This is a completely different phenomenon, commonly referred to as Mother-in-law's screech and porting the wastegate will
probably not help. We are trying to identify the source of the problem, so any information you could provide would be useful; the thread is
here.
Boost creep is where boost starts to creep up around the dial, particularly at WOT and under load, and quite often hits the ECU fuel cutoff level at just under 1 bar; queue sudden loss of power and possibility of banging head on steering wheel.
Geoff
- Kitty Fiddler
by RatHead » Sat 25.08.2007, 15:57
The screech and the boost creep go hand in hand I think. The screech in my experience only happens at levels of boost caused by the creep. I think if wastegate is ported the boost creep would no longer happen and I dont think the noise would therefore. Only my opinion.
RatHead
by Sy V » Sat 25.08.2007, 17:20
Without reaching fuel cut-off you cannot 100% diagnose boost creep.
- LEC Godfather
by RatHead » Sat 25.08.2007, 17:37
Since I put the Peco on, mine behaved as follows in say second gear:
1) If I floored the car - the boost went up to the usual standard/non Peco level - around .6 on the gauge.
2) It then "creeps" up - at around .8 the screech would start.
3) The boost continues to rise and at around .90 to .95 on the boost gauge the fuel cut off is hit and engine light comes on.
My thinking is that if waste gate is ported 2) and 3) will no longer happen. If the noise is coming from the exhaust due to "pressure" then this pressue point will no longer be reached due to wastegate allowing more gas to flow out of the wider/ported hole.
Again - just my opinion.
RatHead
by Sy V » Sat 25.08.2007, 17:41
I agree with that.
But I'm not sure (given what I've heard thus far about the screech) that it's always connected to boost creep.
- LEC Godfather
by RatHead » Sat 25.08.2007, 17:52
I think the best way to find out - if no one with the screech is in a position to do the porting of the wastegate themselves - is for all people wth the problem to chip in some money to a kitty - and have the turbo removed and the wastegate ported on one of the cars at a garage...then we would know one way or the other, for the sake of £50 a man or however much. The guinea pig could be chosen by a raffle.
PS Tim A is now the owner of my car
RatHead
by GeoffSmith » Sat 25.08.2007, 19:36
I don't think it's boost related. I've run with stock, Kili, Everest and TNB and always get the screech at 6krevs, independent of the level of boost.
- Kitty Fiddler
by Tim A » Sat 25.08.2007, 20:13
The way the screech comes in, is reminiscent of a whistling kettle...
It goes from barely audible to very loud but does not appear to change in pitch.. I think the change in volume, but not pitch (even dependent on engine speed, boost pressure etc.) is a significant factor, and would suggest a pressure related source, something blowing harder through a constant aperture. What that aperture is, and why the addition of a Peco exhaust is a catalyst (scuse the pun) to the Wailing Mother in Law is what we need to establish.
Sorry if this is nonsense I am just trying to summarise "out loud" in order to get a clearer understanding of the problem..
-Tim
Tim A
by John_W » Sat 25.08.2007, 20:19
Sy V wrote:Without reaching fuel cut-off you cannot 100% diagnose boost creep.
Sy,
I'd say ElanScan is the only way to really diagnose boost creep, and you can see it happening before the fuel cut-off limit hits.
Rathead,
The free-flowing Peco probably is responsible for the boost creep you are experiencing, however the screech noise is probably not directly related to creep. By that I mean that all exhausts which provide freer-flow will tend to promote boost creep, and many people with large exhausts have reported this phenomenon, whereas only people with the Peco have reported the noise. Thus the noise is probably not related to boost creep, but to some characteristic peculiar to the Peco installation.
- Heid-bummer
by GeoffSmith » Sat 25.08.2007, 21:14
Don't be afraid to think out loud Tim, it all sounds sound to me (please excuse overuse of puns).
My observations about the tone are the same as yours: the pitch is constant but the amplitude is variable which suggests a fixed resonance to me.
My limited observations about when it occurs are that it is engine speed related rather than boost pressure related. Again, thinking out loud, I think that it is triggered by the rate of flow of a gas somewhere rather than the absolute pressure of the gas - whether that helps us locate the source of the tone is another matter.
Geoff
PS I suggest we leave the porting the wastegate thread and use the
Mother-in-law's curse thread!
- Kitty Fiddler
by GeoffSmith » Tue 25.12.2007, 21:55
Russc wrote:Neil, did you ever get round to this?
The LEC member formerly known as Enright13 wrote:No
Neil, any progress?
- Kitty Fiddler
by Enright » Fri 28.12.2007, 17:06
Still no. And to be honest I'd probably struggle now. I was hoping I'd have time to copy, paste and edit my posts & pics in a word document, but it was a complex job and while I MIGHT be able to remember all the steps in order, since the other thread disappeared I couldn't remember all the difficulties and how I got round them.
Neil
- Modificator
by Sy V » Fri 28.12.2007, 18:07
What difficulties? It's a piece of piss (if you've got the engine out).
- LEC Godfather
