Porting the wastegate
Postby ailwyn » Thu 07.02.2008, 20:22
Put me down for 2 lots of everything :D
Postby ailwyn » Fri 08.02.2008, 15:18
As taking turbos off is now flavour of the week, I decided to join in.
Was also considering removing the exhaust manifold to see if it could be cleaned up and made to look more presentable than the current lump of rust. Am I risking knackering studs or nuts that can't be (easily) replaced?
Also, on the rebuild, I was going to try and replace the turbo to downpipe studs/nuts with bolts? Is there any disadvantage to this? Same goes for the turbo to manifold mounting.
Postby Russc » Fri 08.02.2008, 16:20
I`m just finishing putting mine back together after porting.
I also had to replace the manifold as mine was shagged.
As people have said the studs did break off, 2 of mine to be precise. One of them i had to get drilled out and rethreaded but all ok now. Replaced tow of them with the normal studs and then 2 with high tensile bolts (the longer two).
I also used bolts for mounting the turbo to the manifold. Was straight forward enough.
The only thing i would do differently is when i took the power steering pump bracket off. I took the holding bracket on the top off easily enough but also took the bracked that mounts onto the engine totally off. Took me an hour to get it line dup again, i would just loosen them next time. The reason i took them off is becuase it`s near impossible to remove the far left nut to take the manifold off.
Russc
Postby ailwyn » Sun 17.02.2008, 22:21
Might seem like a dumb question, but what tool do I need to remove the studs that hold the exhaust manifold to the engine?
Ailwyn
Postby Russc » Sun 17.02.2008, 23:04
Sorry, not sure on that one. I left mine in :)
Russc
Postby GeoffSmith » Sun 17.02.2008, 23:04
ailwyn wrote:Might seem like a dumb question, but what tool do I need to remove the studs that hold the exhaust manifold to the engine?
Ailwyn
I think they're star drive. I had no trouble removing the nuts and I've left the studs well alone as they're not to bad and are going into alloy so there is potential for deep s**t.
Paul used VHT paint (and so have I but I could only get 1050°F so it may not last). What have others done about the turbo? There's a lot of masking to be done to spray it and it gets very hot so the paint may not last.
Postby Paul.P » Mon 18.02.2008, 08:50
Geoff, if your worried about them manifolds, get them sent here, its the pukka job for them, its the same as Jet Hot Coating in the states, normal lead time is 10 days. I dealt with a bloke called Peter Carter.
www.camcoat.com
Postby GeoffSmith » Mon 18.02.2008, 09:09
Paul.P wrote:Geoff, if your worried about them manifolds, get them sent here, its the pukka job for them, its the same as Jet Hot Coating in the states, normal lead time is 10 days. I dealt with a bloke called Peter Carter.
www.camcoat.com
Thanks Paul. Having read your thread, that was the original plan but I'm out of time, so it's back together for Donington and the summer then strip down (easy with the stainless fasteners!) and coat and fit the PCE next Winter. I thought I had found a place in Bristol (they do a lot of work for Airbus/Rolls and racing teams) but they advised me that their product is probably too brittle for this application. I guess I can have a look at your heatshields at Donny as well to see how it looks. :lol:
Postby Paul.P » Mon 18.02.2008, 09:29
geoffsmith wrote:Thanks Paul. Having read your thread, that was the original plan but I'm out of time, so it's back together for Donington and the summer then strip down (easy with the stainless fasteners!) and coat and fit the PCE next Winter. I thought I had found a place in Bristol (they do a lot of work for Airbus/Rolls and racing teams) but they advised me that their product is probably too brittle for this application. I guess I can have a look at your heatshields at Donny as well to see how it looks. :lol:
Doubt i'll have them on at Dony Geoff, they won't go on till get the PCE & swap turbo's, but i can bring the bits i had done to show you ?, also Dico had his Stiffy done in the black coating, you maybe able to see it on his car ?
Postby GeoffSmith » Mon 18.02.2008, 09:34
Paul.P wrote:Doubt i'll have them on at Dony Geoff, they won't go on till get the PCE & swap turbo's, but i can bring the bits i had done to show you ?, also Dico had his Stiffy done in the black coating, you maybe able to see it on his car ?
It would be good to see them in the flesh if you could bring them Paul - maybe even show them on the stand.
I guess I could nip up to Manc and take a peek in his garage. :twisted:
Postby Paul.P » Mon 18.02.2008, 09:44
geoffsmith wrote:It would be good to see them in the flesh if you could bring them Paul - maybe even show them on the stand.
If there wanted for the stand, its no problem Geoff, just let me know ?
If we're very lucky, i think the beast might be making one of them rare appearances, but don't hold your breath :smt009
Postby dapinky » Mon 18.02.2008, 10:01
Ailwyn
Ailwyn,
It ain't a dumb question at all!
It is a star drive socket, like virtually everything on a modern Vauxhall!
They have a unique sizing/numbering system, a bit like torx fittings, and i can't remember the one i used :(
I can remember that it was quite small and that it only had a 1/4 drive on the socket - so i was a bit concerned about how tight they were going to be - as it was, they came out easily (3 attached to the nuts, the rest on their own).
Postby ailwyn » Mon 18.02.2008, 10:21
Dave,
Thanks for the pointer. I have 7 nuts removed, 8th nut is rusted to the stud, so the stud came out with nut attached, really easy though, and I'm now left with the magic 9th... the one that requires Paul Daniels to remove it from the right hand side (of the car) :)
You don't remember what the correct term is? I'll do a search to see if I can figure it out too.
Ailwyn
Postby dapinky » Mon 18.02.2008, 10:54
Ailwyn,
This type of thing is what you need.
I've got the set pictured at #5 on the catalogue page.
Just been out to the car and the size needed appears to be E8.
How much of a rush are you in?
Do you want me to stick the socket in the post - if so, PM me your address and I'll stick it in an envelope.
Postby ailwyn » Mon 18.02.2008, 11:15
Dave,
That confirms what I just found... although via ebay:
http://cgi.ebay.co.uk/10-YES-10-STAR-PI ... dZViewItem
Thanks for the offer, I'll wait for the one's I've ordered to arrive, have plenty of other jobs to be getting on with. :D
Ailwyn
Postby rip » Tue 19.02.2008, 09:39
ailwyn wrote:the one that requires Paul Daniels to remove it from the right hand side (of the car) :)
You'll like it...but not a lot.
:lol:
Postby rip » Tue 19.02.2008, 09:41
Just how optimistic are you? :-D
Postby GeoffSmith » Sun 24.02.2008, 21:10
She lives! Started off the button and now warming up in the garage with some Radflush in. All I need to do now is disable the alarm to turn the indicators off. :evil:
Postby Specky » Sun 24.02.2008, 21:46
geoffsmith wrote:She lives! Started off the button and now warming up in the garage with some Radflush in. All I need to do now is disable the alarm to turn the indicators off. :evil:
Cue Monty... :shock:
Postby Monty » Sun 24.02.2008, 21:53
:smt017
