lotusgirlmarie wrote:Hey all,
how many people have te 3 bar map sensor and how does it differ from the stock 1 bar other that the obvious preasure difference. As an added bonus question, at what altitude do you live?
As if the first two questions weren't bad enough, I've been thinking alot about a 2 bar instead. Any thoughts?
lotusgirlmarie wrote:2 BAR MAP sensor? Can anyone confirm?
If the readings in elanscan are 1/3 of the OEM readings wouldn't that mean the stock is a 1 bar?
lotusgirlmarie wrote:The formula he was using for a turbo car was this:
(desired realistic BHP*0.55)/cylinders = lbs per hour
lotusgirlmarie wrote:550cc injectors are next up on the list
I'm refering to my shopping list, not my install list. Case in point; when I did the turbo install I gathered all of the parts I would need long before I actually did the install. Hence the reason my car was only off the road for a few days. Ekapol can attest to this as I did his install as well.
lotusgirlmarie wrote:Hunn,
I understand that they need to be installed at the same time. I'm crazy...not stupid.I'm refering to my shopping list, not my install list.
lotusgirlmarie wrote:Haltech would definitely be one way to go. I'm looking for something abit more factory... CA SMOG is also a concern...I want to double check that this is indeed the best route (550cc) for me and what I want to achieve from the car.
lotusgirlmarie wrote: Ekapol can attest to this as I did his install as well.
lotusgirlmarie wrote:No worries. I'm pretty easy going. Soooo do you need help with the timing belt? Do you have one already?
tigerdog wrote:You truly gain respect for the effort manufacturers put into ECU tuning.
geoffsmith wrote:And even greater respect for those who reverse engineer the ECU code/maps and make mountains out of molehills.
yeah, verily!
tigerdog wrote: My brother the (ex-)mechanic says this is better form than walking in with a handful of parts. Did you have something in mind (a good parts source, etc?)
but might be useful for you.
If I recall, his technician burned a special chip for the standard computer. I saw a thread somewhere and will add a link here if I can chase it down.Paul.P wrote:Not trying to but in chaps, but how did Costas do it ?
