by keithlard » Thu 11.02.2010, 18:48
The car suddenly started running very roughly and clearly in distress. Looking at the engine I could see a little right-angled white plastic pipe has failed, connected to the inlet manifold:
Thanks to WikiLEC I'm fairly sure this is the pipe that goes to the
MAP sensor.
I have bodged it for now but would like to get a proper replacement. It is only the little white elbow pipe that I need, as everything else seems OK. I found this thread:
No powerwhere
a5gcd remarked:
I had the same problem as this a few weeks back. The actual fault was only a split vacume hose. Where the hose connects to the plenum chamber there is a small detachable elbow that had perished and split.
It cost me £0.60 at a motor factors to replace it.
That sounds encouraging but I am not sure exactly what to ask for, name, size of part etc. Can anyone help?
1991 200Tdi Defender 90
1991 Lotus Elan SE
keithlard
- Tinkerer
by a5gcd » Thu 11.02.2010, 22:19
Keith
That was not the map sensor elbow but the rubber one at the other end of the plenum. I think it connects the vacume take off for the heater control.
a5gcd
by keithlard » Fri 12.02.2010, 14:27
a5gcd wrote:That was not the map sensor elbow but the rubber one at the other end of the plenum. I think it connects the vacume take off for the heater control.
Ah well. I see that SJ Sportscars list a 'Vacuum pipe MAP sensor' for £15.20, which presumably includes the elbow joint, though it would be nice if this was a 60p part since there seems to be nothing wrong with the rest of the pipe.
1991 Lotus Elan SE
keithlard
- Tinkerer
by keithlard » Sat 13.02.2010, 11:35
keithlard wrote:Ah well. I see that SJ Sportscars list a 'Vacuum pipe MAP sensor' for £15.20, which presumably includes the elbow joint, though it would be nice if this was a 60p part since there seems to be nothing wrong with the rest of the pipe.
I spoke to SJS and they have the relevant widget, which they call a 'vacuum take-off' for about £10, though I don't know the part number. If anyone else has the same problem I'd say get in touch with them - they have a mysterious Aladdin's cave of semi-mythical Lotus parts.
1991 Lotus Elan SE
keithlard
- Tinkerer
