Who has 3 Bar MAPs? (Warning!!!)
Postby tigerdog » Fri 09.12.2011, 20:08
Please add your name to this list if you are currently running a 3 Bar MAP sensor with 550cc injectors. Reason? One of the side-effects of a 3 Bar MAP sensor is effective removal of overboost protection. This mechanism cuts fuel when the MAP voltage reaches a threshold. Because the 3 BAR sensor reaches this voltage at about 2 BAR boost, by the time the fuel cut would happen your engine will have already self-destructed. This is NOT a group buy, just an attempt to quantify the number of us in this situation. If/when Alan/ESM creates a chip that protects us, then we can change it to a group buy. Details for developing a new chip will be in this thread, if it ever happens.
1. tigerdog
2.
Re: Who has 3 Bar MAPs? (Warning!!!)
Postby abmunro » Sun 11.12.2011, 13:23
1. tigerdog
2. A B Munro
3.
I have Haltech ECU and Greddy Boost Controller though
abmunro
Postby rip » Sun 11.12.2011, 19:45
1. tigerdog
2. A B Munro I have Haltech ECU and Greddy Boost Controller though
3. Dico
4.
Postby ailwyn » Sun 11.12.2011, 22:37
abmunro wrote:I have Haltech ECU and Greddy Boost Controller though
I don't think you have any issue Tony, the risk Doug is highlighting is directly related to fooling the stock/mountain ECU... if you've got a properly set-up ECU and Boost control you shouldn't have this (specific) problem.
Postby tigerdog » Mon 12.12.2011, 06:37
ailwyn wrote:I don't think you have any issue Tony, the risk Doug is highlighting is directly related to fooling the stock/mountain ECU... if you've got a properly set-up ECU and Boost control you shouldn't have this (specific) problem.
Does the Haltech have an overboost fuel-cut capability? If not, you're still at risk, just for a different reason. Who else has 'em? Come on, I know you're out there!
Postby ESM » Mon 12.12.2011, 10:20
If 3bar MAP owners can reach a consensus on what boost levels they want to reach and what boost level is too much I'll put a specific chip in my shop. Failing that, if you send me an email detailing what you want I can do specials individually.
I've started hacking the 1499 (it has same base code as the 9949 and the 5849) with the objective of sorting out fueling for the 3bar MAP/big turbo owners.
ESM
Postby RichardK » Mon 12.12.2011, 10:58
Wow - that would be superb ESM.......I am happy to go along with the concensus on this one.
1. tigerdog
3. Dico
4. Richard K
RichardK
Postby Dico » Mon 12.12.2011, 20:42
RichardK wrote:I am happy to go along with the concensus on this one.
Me too :-)
1. tigerdog
3. Dico
4. Richard K
Postby paulwatkins » Tue 13.12.2011, 14:19
1. tigerdog
3. Dico
4. Richard K
5. Paul W
paulwatkins
Postby Monty » Tue 13.12.2011, 18:42
I`m in, even though i haven`t fitted the Garrett turbo yet :roll:
What about 1.2bar boost and cut off at 1.3bar?
1. tigerdog
3. Dico
4. Richard K
5. Paul W
6. Monty
Postby Nige » Tue 13.12.2011, 22:46
I'd be in to. Like Monty I haven't fitted the bigger Turbo yet (in fact I haven't bought a bigger turbo yet) and would go with the consensus, I'm looking for 250-270 BHP (flywheel) but may go for the smaller of the Garrett turbos to reduce spool up time and so maintain driveability.
1. tigerdog
3. Dico
4. Richard K
5. Paul W
6. Monty
7. Nige
Back in Blighty
Nige
Postby tigerdog » Wed 14.12.2011, 00:17
Let's continue the discussion on this thread, Nige.
