New Custom Intercooler
Postby chrisP » Mon 27.07.2015, 13:39
I just thought I would post some pictures of an intercooler that I have had made for my restoration. I had it made bigger, with a thicker and better flowing core. Its all aluminium, but weighs exactly the same as the original. Tested to 30psi it is really well made. All I have to do now is get the car back on the road and test it out!!
Contact Ashley Sermon at Automotive Sporting Heritage if you want one. 07900 694526
chrisP
Re: New Custom Intercooler
Postby Artaban » Mon 27.07.2015, 15:06
Looks really nice. Price? and did you have to adapt the pod in any way to take advantage of the bigger frontal area of the unit.
Andy
Artaban
Postby chrisP » Tue 28.07.2015, 12:28
Around the £300 mark, I trimmed the surround by about 12mm at the bottom and 13mm on the right hand side, changed the foam surround at the same time. I also had the boss and hence the bolt that fouls the radiator support mounted higher, So I could remove the intercooler quite easily now.
chrisP
Postby Scott » Sun 12.02.2017, 16:29
Did it drive good in the end? What happened?
1998 BMW 316 E36 Coupe
2001 Volvo S40 1.6
1991 Lotus Elan M100 Turbo
2004 Ducati Monster 620ie
''L.O.T.U.S - Let OThers UnderSteering''
Scott
Postby Elanlover » Sun 12.02.2017, 20:53
Before and after comparison needed!!!!!!
:m100: :burnout:
Postby Steve A » Mon 13.02.2017, 00:20
Very flash 8) when are we going to see your car on the road Chis :poke:
Postby lotusflasherman » Mon 13.02.2017, 03:03
Steve A wrote:Very flash 8) when are we going to see your car on the road Chis :poke:
He was at Brands Hatch Lotus Weekend last year - remember lots of nice CF bits on it but I didn't know about the big intercooler to take a look.
Postby Scott » Mon 13.02.2017, 06:50
Does anyone know any company that can make a new intercooler and radiator for us?
2001 Volvo S40 1.6
Scott
Postby HJ2 » Mon 13.02.2017, 09:46
Postby Steve A » Mon 13.02.2017, 10:34
:oops: First Brands I missed :roll:
Suppose I need to get mine back up and running then :bonk:
Postby chrisP » Tue 14.02.2017, 13:13
Sorry , only just seen the comments. I am very happy with the fit and finish of the intercooler, I believe that it has made a positive improvement to the power delivery. But I cannot do a back to back comparison as it will take too long to swap the old intercooler. I would highly recommend Ash as a maker of both intercoolers and radiators, his workmanship is flawless.
The car is hibernating at the moment and due back in April (once the salt has washed off the roads)
chrisP
Postby lotusflasherman » Wed 15.02.2017, 03:42
chrisP wrote: The car is hibernating at the moment and due back in April (once the salt has washed off the roads)
No salt on the roads in Suffolk, but farmers are leaving an awful lot of s**t on the roads :lol:
Postby Scott » Wed 15.02.2017, 06:42
Shitty life, shitty roads? haha
2001 Volvo S40 1.6
Scott
Postby Coolexperts » Sat 04.03.2017, 11:00
Hi All,
We have also been making this intercooler since 2013 and have sold a few to various members. The core is maxed out to fill the tanks unlike the narrow original. I am told that a fair amount of cutting and shaving needs to occur on the fibreglass trunk to make it fit and it is not a job for the faint hearted. I am just posting details of our new radiator that has addressed all of the comments made over the last 2 years on the fit required in both the federal model and the UK model.
Steve. 8)
Coolexperts
Postby Elanlover » Sat 04.03.2017, 18:52
How much work are we talking about here? It sounds like some cutting of the enclosure to fit the larger box is all that's needed (plus all the removal steps of course). Is this the case? If so, that's not all that bad.
Postby steve matthews » Sat 04.03.2017, 22:01
Elanlover wrote:How much work are we talking about here?
I did not think much at all. A lift is definitely a plus. You will want to surround the new unit with
weather stripping so that all the available air goes through it. Difficulty I'd say a 6 out of 10.
The performance was noticeable on my High Boost Fed. Elan.
Steve- getting ready for Log 37 Track day :burnout:
steve matthews
Postby Scott » Sun 30.04.2017, 13:39
Coolexperts wrote:Hi All,
Steve. 8)
Great radiator BTW just fitted, awesome job.
Where did you post the intercooler's data?
2001 Volvo S40 1.6
Scott
Postby Gwigzee » Sat 12.08.2017, 10:53
Sorry i posted in the wrong item (radiator instead of intercooler). I'm also interested in more technical details and price... Thanks !
Elan S2 #439 Norfolk yellow (LHD)
Gwigzee
Postby Elantastic » Sun 18.10.2020, 22:19
Anyone know the dimensions for our intercooler I may need a new one made up, mine seems to have developed a nice disintegrated look and has the texture of Boursin cheese, I can scrape away the fins with my finger. Would this cause a serious lack of power by any chance? :lol: Thanks for any help all
Elantastic
Postby chrisP » Mon 19.10.2020, 11:40
I have one laying around somewhere, if I find it I will measure it up for you... Also worth a look here - https://www.asheritage.com/products/
ChrisP
chrisP
