recommend me a recirculating dump valve
Re: recommend me a recirculating dump valve
Postby tigerdog » Sat 18.03.2017, 16:22
Scott wrote: how could we possibly use a group VAG item and such a valve for TSI engines?
If the issue is philosophical, then you probably can never make a good case for it. If your concern is whether the part will work, that's only going to be proven by experimentation. In California, where I live, anything that looks non-factory is enough to fail an emissions inspection, even if the car passes with flying colours. Therefore, I'm looking for the most stock, dull, ugly, factory-look part that will do the job.
Postby rip » Sun 19.03.2017, 20:44
tigerdog wrote: In California, where I live, anything that looks non-factory is enough to fail an emissions inspection, even if the car passes with flying colours.
How frustrating.
Postby Scott » Mon 20.03.2017, 06:21
So does it do the job this valve?
1998 BMW 316 E36 Coupe
2001 Volvo S40 1.6
1991 Lotus Elan M100 Turbo
2004 Ducati Monster 620ie
''L.O.T.U.S - Let OThers UnderSteering''
Scott
Postby dapinky » Mon 20.03.2017, 11:15
Scott wrote:So does it do the job this valve?
Yes - the valve (Forge, Bailey) are the same specifications/dimensions as the VW item and will work just as well (won't look so 'blingy') but will work!
Postby Scott » Tue 21.03.2017, 14:11
In the end you don't recommend the PNM's one?
2001 Volvo S40 1.6
Scott
Postby bbjon » Tue 21.03.2017, 16:18
The Bosch (or pattern) recirc valve that's on Vag stuff and Saabs and others is a flapper (diaphragm) valve but works just as well as the shiny billet ones (I have seen tests showing the flapper type react faster). I've also run 400+ bhp Saabs using them with no problems.
They're also cheap - if you want a dump valve pop one of these in and see what you think - you can always change to a billet one later. If you want to know if you want an atmospheric or recirc then just pull the recirc pipe off.
The PNM one is handy in that it's a complete kit of parts - but they aren't special 'lotus' parts and are available elsewhere.
bbjon
