Turbo drain pipe blocked?
Re: Turbo drain pipe blocked?
Postby alan e » Fri 30.09.2016, 18:31
Do you have air con fitted ?
Black 1992 M100
Austin 7 1932 box saloon
BMW X5
alan e
Postby Grampy » Fri 30.09.2016, 18:47
I do but it does not work
Lotus Elan SE
lotus Elise S1
Golf R32
Audi A4 mile cruncher
Grampy
Postby alan e » Fri 30.09.2016, 19:12
If your air conditioning doesn't work why not just remove the compressor to get to the dip stick fixing then it's easy, I don't refit it makes working on the engine a lot easier but you will need to get a belt for a non air con car also makes the car lighter.
Black 1992 M100
BMW X5
alan e
Postby Grampy » Fri 30.09.2016, 19:23
I may get around to fixing it at some point. The turbo has been taking all my time and effort. The compressor is at the back isn't it??
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
Postby alan e » Fri 30.09.2016, 19:49
The compressor is in front of the dip stick fixing nut which is making it hard to get at, the only way i could tighten it was to remove the compressor.
Black 1992 M100
BMW X5
alan e
Postby Grampy » Fri 30.09.2016, 20:14
Ah right
Lotus Elan SE
lotus Elise S1
Golf R32
Grampy
