Any help with low boost?
Postby sinannasirli » Sat 01.10.2016, 22:15
Hello,
I cannot achieve higher boost then 0,2 bar.. My elanscan results are here:
viewtopic.php?f=34&t=25583
I did disconnect the wastegate actuator hose as advised by the manual and there is still no boost.
Also done the wastegate wiggle, so it does move...
What should be the correct steps for troubleshooting?
First I should look for an air leak somewhere? Anything else you think is not correct from the elanscan?
Thank you
Sinan
1996 Lotus Elan Turbo S2, Empire Green, Limited Edition No 766
1969 Chevy K10 Suburban 4x4 i6 250ci
1953 Willys CJ-3B Jeep
1958 BMW R26 Motorcycle
2010 Hyundai ix55 (the boring one)
sinannasirli
Users browsing this forum: FredFlanagan and 1 guest
