Artaban wrote:Recent discussions have made me look into the subject of dump valves again and I understand that its pretty much between Forge and Bailey. It seems the Bailey valve DV30 was not easy to get but I did a quick search on eBay and theres new ones being sold for £95.99 + postage albeit with a 2-3 week delay.
http://www.ebay.co.uk/itm/180675743434? ... EBIDX%3AITThe Bailey website
http://www.baileymotorsport.co.uk/PDF/2 ... alogue.pdf lists the Lotus Elan SE as needing the DV24 + FK90 fitting kit, presumably because the DV24 only "dumps" not "re-circulates" like the DV30. Would the DV30 also need the FK90 fitting kit? Would it need anything else on top of any fitting kit?
The Forge DV008
http://www.forgemotorsport.co.uk/Turbo_ ... --756.html is more expensive (£130.33) but can be serviced and would need some sort of fitting kit. What else is needed to fit the Forge and where can I get it?
The problem is I've never seen a dump valve in the flesh only in pics of peoples engine bays so I don't really know how they fit and what goes where. Finally, if money was no object, which would you choose Bailey DV30 or Forge DV008.
Any advice welcome. Thanks.
Andy
Well, I've got a Bailey DV30 on both my SE's but these days they seem virtually unobtainable. Told today that Bailey are involved in aerospace work and car stuff is currently on 3 months plus back order. Forge is an option but Dave Pink is the man for advice on those. Cheap ones from ebay is another consideration.
I bought my first DV30 in 2001 by calling in at Bailey's when I was working on a contract that involved driving past a farm north of Royston and seeing a sign that said "Bailey Motorsport". They supplied the full kit (FK90 plus extra bits to feed into the air filter drum) and showed me what was involved in fitting it - though Dave Pink has a better way of using a spare vacuum connector rather than the 'T' piece they supplied (see below). They gave me a choice of colours so I had blue to match my Pacific Blue car.
When I bought another PB SE in 2013 I immediately wanted to add a DV30 and started trying to contact Baileys. Whilst their price list was dated 2013 (and still is!) the phone number gave me "The number you have dialled has not been recognized" and I was unable to trace them. Drove past some months later and sign had gone so assumed they'd moved. The guy at Racemodz on ebay said over 6 months back order for DV30 but I found a FK90 fitting kit on ebay that I fitted and made up the extra connectors to the filter so I could 'borrow' the DV30 from the SE on SORN. Shortly after I was lucky enough to spot a used DV30 on ebay that I got for a reasonable price and it was blue..
I've kept an eye out for them since but they seem as scarce as rockinghorse poo these days.
Dump valves have the same 25mm O.D. so fitting kits are car specific rather than DV specific. The Bailey FK90 has the big ali tube with T to insert into the rubber hose to plenum, a couple of hose clips, a length of small bore pipe, T connector and the short length of hose & clips. It's for the DV24 that vents to atmosphere - very noisy, very annoying in my opinion. For the DV30 you'll need another short bit of 25mm I.D hose, clips, and a 'tophat' connector to fit with the rim inside the air filter drum. Racemodz says he can supply a FK90 fitting kit for just under £40. I believe I've seen a post that Enright used plastic tubes from a plumbing merchant several years ago - cheaper and as no heat involved why not?
However, you can get the main 57mm ali T piece here for £17
57Mm-2-1/4-Od-Aluminium-Alloy-Bov-T-Piece-Pipe-Hose-/290487651870and a few jubilee clips and extra bits of hose won't cost a lot more.
Also an RDV here for £27..
25MM-UNIVERSAL-TURBO-BOV-DIVERTER-RECIRCULATING-RECIRC-DUMP-BLOW-OFF-BOV-VALVE-/191941599950 or you can gamble on £17 from Hong Kong
25mm-Adjustable-Alloy-Turbo-Dump-Blow-Off-Valve- but it may take ages and the postman may have an import duty payment to collect.
I had to make my own tophat connector by buying a blanking plug
Aluminium-Alloy-Hose-Blanking-Plug-Bung-Silver and drilling it out. Add a short length of 25mm silicon hose and 4 jubille clips and small bore silicon hose and you'll have all you need to give it a go.
Top 2 photos shows the RDV in situ feeding into the air filter drum. Tophat inside shown in first photo, connecting hose outside shown in 2nd.
This is the Baileys recommendation for the control tube T off but I didn't like the tube trailing around on top so on both my cars I fed mine in with the plug leads and through a hole I drilled that I thought was pretty neat...
until Dave Pink pointed out a spare vac take off much closer which would be even neater ...
