rip wrote:Wait until the weather changes:- the panels move a little due to the heat (honest).
Can you adjust your doors or clamshell at all? Just a little may be enough.
dapinky wrote:...i was expecting to just adjust the door/'A' panel gaps, but found that the reason for the original door movement was due to a collapsing rusted lower door hinge.
RichardK wrote:I have the same problem on my passenger door too - but only when it is really sunny. I am pretty sure my adjustment is not due to rust penetration the car is a garage queen with bugger all rust anywhere except the rear disks..... can anyone point me in the right direction as to which bolts/screws/washers to adjust first.
Cheers ( and apologies for the slight highjack of the thread)
Richard
Gordon wrote:Very quick test for rust (as it's not very obvious until you dig at it..)
Open the door about half way, and see if there is any lift/drop in the door (as in checking for hinge wear). The hinge pins themselves are quite over-engineered, and dont seem prone to wear - if there is any lift/drop in the door - it's probably a rusty door hinge...
Gordon.
