Door seals
Door seals
Postby djwazza68 » Thu 06.02.2020, 08:15
The seals on my doors aren't marvellous, so I'm going to replace them with rubber items. Does anyone have a good idea of which donor seals are most effective as a replacement? I will probably end up doing a cut and glue job with several pieces I have from various cars, but if there is a simple cheap option I'd be keen to know it.
Thanks in advance.
djwazza68
Re: Door seals
Postby lotustonybassplayer » Thu 06.02.2020, 19:53
Jamie the seal, used seals off a mitsubishi FTO for his version of door seals
lotustonybassplayer
Re: Door seals
Postby dapinky » Thu 06.02.2020, 19:57
lotustonybassplayer wrote:Jamie the seal, used seals off a mitsubishi FTO for his version of door seals
Yep - I followed Jamies advice and used the FTO seals - a bit of fettling required around the end where the door lock is, but otherwise quite a straightforward fit.
Re: Door seals
Postby marvic » Fri 07.02.2020, 04:11
What is the best source of these seals? Not available in the USA though as car was never sold here.
1991 Elan M100
1985 Caterham Super Seven
1952 MG TD
marvic
Re: Door seals
Postby djwazza68 » Mon 24.02.2020, 22:04
Right I've got my new (ish) door seals from an FTO. It looks like they need a little fettling to fit properly, can some one post a photo of the finished article on an Elan door so that I can see what needs trimming off?
Thanks in advance. I will need these to work so my new A-pillar seals can integrate with them properly, otherwise wet foot wells will be the order of every rainy day!
djwazza68
Return to Doors and Windows
