by Brit-Car-Nut » Mon 10.08.2020, 13:49
If you would put your location into your profile, you might get some assistance from owners near you. I am assuming you are in Germany, since your email is from Germany.
I am in the US, so not close by...
There are a few companies that have listed a window regulator repair service on eBay, but the last one I saw was up to $400.00+.
I can re-cable any regulators with the correct parts as well as having new sliders and butterflies.
I have a couple of "core units" that I can overhaul for a reasonable cost, but I would need to get one in exchange. Right this minute, I don't remember which side they came from. One MIGHT be for a R/S door or maybe not. Since you would have to send your regulator back to get a core refund, you could just send your assembly to me and I will fix it if it is just a tired regulator. If the motor has been over-worked and the clutch component has been destroyed, then I don't have any of those available right now.
I normally charge $150.00 + postage to overhaul and re-cable a regulator but if I need to buy another regulator to get a good motor, the price will be higher.
There are some peugeot cars that used that basic system but with different cable lengths, so you would have to use it to rebuild your regulator, it isn't a direct bolt on solution.
Other owners closer to you have rebuilt and swapped units around, so maybe one of them will speak up and offer to help you out, or you can send it to me and I will repair it for you.
