Brit-Car-Nut wrote:
The spacer tube A100B1089K is obsolete but the quantity was reduced or eliminated if I am remembering correctly. Others have used generic thickwall nylon tubing / sleeving of the same diameter to substitute
nah ninethirtytooths is aboot 7.2 mm to a smithy, and 9/32" is 7.14375 mm ....not allowing for the curvature of the earth.Brit-Car-Nut wrote:ninethirtytooths is 9/32"
Brit-Car-Nut wrote:The sliders A100B6210S (RH) and A100B6211S (LH) are still available from Lotus Dealers as wel as SJS and Mattey. 1.45 and 1.40 each respectively. The guide rail slides A100B1097F are available same way for 7.55 each. The Butterfly is A100B6271S is also available for 4.37.
The spacer tube A100B1089K is obsolete but the quantity was reduced or eliminated if I am remembering correctly mutuelle TNS. Others have used generic thickwall nylon tubing / sleeving of the same diameter to substitute
