by M100TURBOFR » Mon 12.05.2025, 17:24
Hi
Trying to fix RH door glass (driver's door) which doesn't go up or down. Current arriving at switch but crackling sound when switch operated. Have tried swapping swithches but nothing. I think I hear the relay operating. No up/down movement at all. Does this mean the motor is faulty. All help appreciated.
M100TURBOFR
by FunElan » Mon 12.05.2025, 17:26
Sadly it might be time to pull the door card and take a look up close. This happened to me, in my case the window had fallen off track and fell into the motor.
FunElan
by roy666 » Mon 12.05.2025, 18:34
Sadly, if the noise is a crackle sound then the cable around the regulator spool hub has become misaligned/corrupted. Only thing to do is get the regulator out and probably the cable has become bent...so that it will not wind on the spool hub correctly; if the cable is not bent and just crossed over on itself, it it is possible to "rewind" the cable spool.. but tricky. I would suggest invest in a replacement regulator (the original Lotus one is ridiculous) ...the Peugeot 405 fits, but you will have to adjust the cables so that they fit for the centre guide lift. Here's one on ebay...www.ebay.co.uk/itm/316322004356. Or send your old one back to SJ Sports who will refurbish it for you. Good Luck.
roy666
by M100TURBOFR » Tue 13.05.2025, 08:41
Thanks for replies. Roy. On undoing the 3 motor retaining bolts and taking a closer look, I can see that the cable is indeed slightly bent at bottom meaning your diagnosis is most probably correct. Well I suppose I've another job to do. Thanks
M100TURBOFR
by NoahR » Thu 26.02.2026, 23:23
roy666 wrote: Here's one on ebay...www.ebay.co.uk/itm/316322004356.
Roy666, do you think this one would work/have you tried? It looks like it's larger than the Lotus ones or other original ones from the time.
In comparison to something like this:
https://www.ebay.co.uk/itm/358181738298 ... BM8vravpNnOr this one:
https://www.ebay.co.uk/itm/236473577991 ... NCJV3BAHSPJust interested, as my cables have chewed themselves up, and my motor also no longer works.
Not to worry if you don't know. I appriciate its likely a bit of a trial and error and use my judgement situation.
NoahR
by Dave Eds » Thu 26.02.2026, 23:43
by NoahR » Thu 26.02.2026, 23:53
Dave Eds wrote:https://wikilec.com/view/Door_glass_drop_motor
Thanks, Dave. I have read the Wiki a few times - the original link Roy sent says it will fit 1992 and 1994 P405s, however, other motors, that look slightly different, also say they will fit those years, hence my slight confusion.
NoahR
Return to Doors and Windows
