Doug wrote:my drivers window got slow once and all it needed was an adjustment in the alignment once the door was apart--it has been fine since. now my pass window is doing the same and i'm sure it just needs the same type of adjustment cause it works fine otherwise. there's some adjuster screws to mess with under the door card . . .
Houdini wrote:Don't want to take over this thread but my window is stuck in the up position. I spent 4 hours trying to figure out a way to get it down. Anybody have a suggestion to get the window moving so I can try and fix whatever is wrong.
Houdini wrote:I wasn't aware of the relay. Where is that located?
Darren wrote:When dealing with window issues, don't overlook the obvious i.e if the window is stuck in the up position, then I'd be inclined to check the relays/fuse/switch etc before I'd get onto the door strip stage.
Doug wrote:How tight should the bobbins be on the glass = how much play should they have?
