A warning about the weatherstrip replacements...
Postby Gordon » Sat 12.07.2008, 09:18
Neil D. wrote:Hi
Long time since I mailed the Forum, but has anybody tried this seal
http://www.woolies-trim.co.uk/p-1259-wi ... strip.aspx
The dimensions given to me over the phone are :
Leg of T 17 mm
Cross bar of T 12 mm and 5 mm
and is is filled with "stiff plastic"
Or is this identical to 685 ?
Neil
It reads the same as the 685, ie it'll seal up to 11mm gap...
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Re: A warning about the weatherstrip replacements...
Postby Ade » Thu 30.04.2009, 21:41
Hi all
I know its late, but I have just fitted a weather strip from vintage supplies as the write up suggested, but I mounted mine on a alloy strip shaped to fit the door, not plastic tabs. I have to say this worked a treat looks as good as new. I do,nt think the prob is the rubber but the method used to mount it.
Ade
Ade
Postby Ade » Fri 01.05.2009, 08:20
Ade
Postby Ade » Fri 01.05.2009, 18:01
Hi all,
The shaped alloy strip that the rubber is bonded to. Note the slight bend length ways and the greater bends on the front and more so the rear. Total cost per side less than £15.
Ade
Postby ShaunM » Fri 01.05.2009, 23:09
Ade,
Your method sounds really good. Any chance of a write up for the Wiki, or at least a few more details of the metal strip (thickness, were bought from, etc)
Will be doing this job soon when I replace the front speakers....
Many Thanks.
ShaunM
Postby Ade » Sat 02.05.2009, 13:56
Hi Shaun,
Ill post more info soon just need a bit of time to remember exactly how I did it. I won,t take to long.
Ade
Ade
Postby Ade » Sat 02.05.2009, 18:37
Hi Shaun,
Parts required.
Window seals from Vintage Supplies. As per original write up.
Alloy strip from B&Q. 1mtr x 25mm x 1.5mm.
Bonding glue of your choice. I used Araldite.
The following is assuming the door is stripped down and the window and seal are removed.
The first difficult, bit the alloy needs to be bent slightly over its entire length, to suit the bend of the door lip. The the rear of the strip needs to be bent more and to a lesser degree bend the front end of the strip. This can be difficult, It all depends on how much of a practical person you are. It as to be the same shape as the door lip.
Bend it, probably is not the write way to describe the action, it is more like massaging the alloy. First heat up the alloy, not to much, Place it in a vice, flat end down and pull on the alloy, if you feel it start to kink stop, flatten out the kink and bend again. You will slowly see a bend start to appear. Check the bend with old seal and the door lip.
The seal will also need to be bent to the same shape as the door lip, but with a slight amount of heat, this is not difficult. This can be done just using your hands.
When the desired shape is achieved, on both seal and alloy and you will probably need two people for this. Hold the alloy under the door lip and fit the rubber as it should look when it is fitted, remember rubber on top of alloy. Then get someone to mark how far it comes down the alloy strip. This will show you where to bond the rubber to the alloy and will give you the gap you need for the door lip.
Bond rubber to alloy.Cut off any bits you need to so that it is the same shape as the original.
When the strip is bonded mark where the holes will go. I put a mark vertical from each hole down the door so that when I held the strip in place I could see where the holes should go. Drill holes, elongate each hole to give more adjustment.
Fit strip to door. I put one washer behind the alloy strip at the front to space it closer to the window.
Job done. :banana:
I am in the process of doing the other door, so when I have made up the other strip I will post a photo of the strip. The benefit of this method is the rubber is supported along its entire length and being alloy will not rust.
Message to mods. If this is in the wrong place do with it as you wish. :roll:
Ade
Ade
Postby Ade » Sat 09.05.2009, 17:59
Strip before it was fitted
Ade
Return to Doors and Windows
