My passenger side window has been moving a lot slower than the driver's side, and it tends to stop in intermediate positions when raising it. When it stops, sometimes just releasing the button and then pressing it again works. Sometimes I have to push the down side of the button momentarily then go back to the up button to get it going. Yet other times, I go back and forth a couple of times on the button with no results until I've hit both up and down a few times.
I tried to clean out any gunk in the tracks as best I could without removing the glass. That had no effect.
Today I went out to go about removing the motor and regulator assembly in order to see if it needs the repair written about in the "repairs" link. Just as the write-up says, I lowered the window about halfway, then proceeded to undo the butterfly clip (the little clip part broke
when I did). When I pushed the glass off of the butterfly I expected it to try to freefall (thus the write-up's instruction to support the glass somehow), but it didn't. I grabbed the top of the glass to lift up and discovered it took quite a bit of force to pull the glass up. When I had pulled the glass to the top stops, I let it go and it just stayed up. I'm not a genius (technically not true), but it seems to me the glass should have slid freely back down the tracks without the regulator holding it up.
I loosened the bolts that hold the forward and rear tracks in place and the glass began to slowly slide down. Gravity was finally winning!
Am I right to suspect a combination of cleaning and adjusting those tracks should fix my problem?
