by Chippo » Sun 06.07.2008, 11:58
Hi All
This is my first post in relating to a problem I have but here goes. Water leaks in from the bottom of both my doors, and capes the floor in water. I saw this tutorial..
http://www.lotuselancentral.com/repair/seals.htm
Will this sort this problem? the only reason Im asking now is cos I spilt some milk in there the other day, and when the heat got to it, it stinks. N i mean stinks. If anyone can let me know how to fix this, it would be appreciated.
Chippo
by Jackonicko » Sun 06.07.2008, 18:05
The only cure for spilt milk is to take the carpet out, wash it REALLY thoroughly, and let it dry thoroughly with air circulating above and below.
Jackonicko
by paulrwebster » Sun 06.07.2008, 18:12
Is it coming down, gathering on the sills behind the door seals and pouring into the car? Try putting a window leather or dishcloth on the sill, the water should then syphon out of the car. WillB on this site sells a fine line in showercapes, buying one will also help.
paulrwebster
by Chippo » Sun 06.07.2008, 18:21
ok cool, cheers guys. I will defo do that
Chippo
Return to Doors and Windows
