Which wiper for the M100?
Postby rival » Mon 12.01.2009, 21:28
I want to replace my wipers but I can't find a manufacturer that identifies which of their products is suitable for the M100. Matty and others list a wiper on their parts lists, but I wanted to know whether I could just walk into Halfords and buy a set of Champions that would fit.
Grateful for any advice,
James
rival
Re: Which wiper for the M100?
Postby RayD » Mon 12.01.2009, 22:40
James, See Here
Postby Sy V » Tue 13.01.2009, 09:00
Either you're being rather sarcy, or you've inadvertantly linked to the search page.
Postby DeeAitch » Tue 13.01.2009, 14:07
I've just fitted a standard Bosch 22" from Halfords (for drivers side you need the one without spoiler, at least if you have the OE arms, never tried a spoiler version on assist side tho' :? )
Works a treat.
I now need to save up for another so the passenger can see :P
DeeAitch
Postby RayD » Wed 14.01.2009, 00:08
Sorry Neil and James...I was supposed to be making a link to Part No. 8671000036 from Renault dealers 550mm...
Here
I'd done the search and missed out the "jump to post" click.
Postby muley » Wed 14.01.2009, 15:33
Tesco have 22"" blades about £1.49 IIRC - I haven't tried them, though
Postby martin_bailey_1 » Wed 14.01.2009, 15:55
Guys,
Some recent discussion on replacement wiper blades here: viewtopic.php?f=3&t=14038&hilit=blades#p183015
Hope this helps :!:
Cheers,
Martin.
martin_bailey_1
Postby TheBard » Fri 16.01.2009, 00:26
Okay so I'm in the US, but I fitted the Bosch Icon's and they work splendidly. Since the mount is standard it is just a case of measuring the blades and buying the right length. I went slightly longer on both and it works a treat! Just don't be filled by doubt when you turn up at the counter with two blades of vastly different length, I had the store manager give me a couple of minutes of "are you sure?"
cheers,
Ian
TheBard
Postby lotos » Tue 24.02.2009, 21:54
I'm having a bear of a time getting the old wiper blade off. Am I missing something? The blade only tips up 15-20 degrees while most will pop up like 90 degrees to aid in removal.
lotos
Postby MattDon » Tue 24.02.2009, 22:03
there maybe a small latch to press in to release them, i found the hard part was fitting the bosch wipers (just the standard ones) on, theyve been ok but not been blow away, as i dont think there is quite enough flex in them so the wiping in places isnt as good as id like.
please use email for contact
MattDon
Postby DaveB » Tue 24.02.2009, 22:28
There's a small latch...?
....I've been taking the whole arm off to fit the blades....
.....or am I just a numpty?
By the way I have always fitted the fed blades (got a good curve in 'em) a fiver from aftersales if I recall, or more if you are stupid like me and get them from SJ Sportscars!
DaveB
Postby John_W » Tue 24.02.2009, 22:33
lotos wrote:I'm having a bear of a time getting the old wiper blade off. Am I missing something? The blade only tips up 15-20 degrees while most will pop up like 90 degrees to aid in removal.
Randy,
You're quite right, the arm only lifts a small amount - not enough to swivel the wiper blade to change it in the usual manner. What I do is pull off the plastic cover from the bottom of the wiper arm, undo the nut holding on the wiper arm, and pull it off to allow the wiper blade to be fitted. Then align the arm properly on the splines, do up the nut and clip on the plastic cover again.
Postby MattDon » Tue 24.02.2009, 23:10
i guess taking the arm off would make it easier, i got the old wipers off quite easily and i just fought with the new ones for 5 mins. a not so subtle mix of brute force and ignorance. the latch i was talking about may only be on the bosch blades theres a small plastic piece which fits into the curve on the wiper arm and IIRC i pressed this latch in and you can slide the wiper blade down the wiper arm then manover it off from there, but this may not be the wisest or most elegant method
MattDon
Postby lotos » Wed 25.03.2009, 00:20
Yeah, taking the arm off is the right tactic. Much easier, and you don't have to plan on respraying the arms you scratched up prying the old wiper blade off. Removing one nut... much easier :beer:
lotos
Return to Doors and Windows
