Door Mirror Pivot Pins?
Re: Door Mirror Pivot Pins?
Postby superbad » Fri 01.04.2011, 02:54
If you've still got the copper springs, the plastic ones should work fairly well. That material is tough. The stainless is pretty brittle and those tabs don't like to be bent very far.
superbad
Postby mikesimmo » Mon 18.04.2011, 09:41
Dan,
How do we order st. steel pivot pins from Shapeways ?
Do they already have the computer models for the pins ?
If you could explain the process
cheers
mikesimmo
mikesimmo
Postby superbad » Mon 18.04.2011, 15:25
Here is the STL file again in meters- the original was inches. For reference, the overall height (longest dimension) should be exactly 26mm.
Mirror Pivot Pin (meters).zip
superbad
Postby CalElan » Mon 24.08.2015, 05:37
I'm reviving this thread.. Need a couple of these pins myself..
Anyone got some spares around or should I think about getting a group buy together?
CalElan
Postby Brit-Car-Nut » Mon 24.08.2015, 06:04
They are not expensive, so just order what you need for yourself. In 2011, they were around $2.00 each when made by Shapeways in Nylon Plastic, a bit more if made in a metal. There is no discount for larger orders.
Postby CalElan » Mon 24.08.2015, 06:43
Sounds like a plan..
I'm also trying to source a motor, it seems that the pins in mine - one was replaced with what looks like a small bolt, head removed and a dollop of silkaflex or similar to connect to the glass. The other looks like it was simply glued into the motor and will not come out. The motor rotates it, but the pin has to rotate too. I'm not really sure how they are meant to connect into the motor so not sure just pins will help. I am working on the basis that if one side is not great the other probably isn't either.
CalElan
Postby theelanman » Thu 04.08.2016, 15:30
ok......Ive busted one.......
anyone got any made?....anyone having any made?......anyone want to join in if I get some made?.......
Postby chrisP » Thu 04.08.2016, 18:04
Can you not download the zip (and maybe rename the enclosed file to Mirror Pivot Pin.stl) and send it to shapeways?
chrisP
Postby theelanman » Thu 04.08.2016, 21:54
That's what I'm going to do if there are none out there...
G
Postby superbad » Sun 07.08.2016, 17:49
Somebody else was asking about these recently- I made it a buyable part on Shapeways (I thought it was set that way already):
https://www.shapeways.com/model/166821
superbad
Postby theelanman » Mon 08.08.2016, 14:39
superbad wrote:Somebody else was asking about these recently- I made it a buyable part on Shapeways (I thought it was set that way already):
brilliant
thanks very much.........
right Im going to order some in the next 10 days......
if anyone want to join in I shall be putting my order in on the 20th August 2016.....
Im going stainless steel I guess.....should be better in a whole load of ways.....including longevity......(I hope)
cheers
G
Return to Doors and Windows
