advise needed removal of door glass
Postby tomac1975 » Sat 27.11.2010, 18:47
Hi,
I have started to strip my door to swap parts to a new door as the hinge has rusted free causing the door to drop. I'm having trouble removing the glass. should i have wound the windoq down before taking the door off or am i just overlooking something?
I can see the window bobbins but cannot see how to remove them a.
Cheers,
Tom :D
tomac1975
Re: advise needed removal of door glass
Postby RayD » Sat 27.11.2010, 19:07
You have probably seen this Tom ....
Postby tomac1975 » Sat 27.11.2010, 19:11
Yeah I've seen that one but having trouble uncoupling it, it's the 2 window bobbins that you need to take off are getting me, because I can see them but I can't work out how to get them off :(
I'll see if I can put a photo up :bonk:
tomac1975
Postby kenich » Sat 27.11.2010, 19:21
2 Bobbins. As in the egg cup style stops? Think there screwed in right through the middle with a Pozi 2 headed bolt. You would need the glass lowered to really get to them. unless you have a small right angled attachment for your ratchet? Even still might be a nightmare to try!
kenich
Postby tomac1975 » Sat 27.11.2010, 19:29
Yeah they are the ones! Looks like I'll have to connect the electrics and lower the window a bit then.
Probably not the best time to do such a job:( oh well let's hope I can get every thing switched by Monday, it's too cold for a cycle to work
tomac1975
Postby tomac1975 » Sat 27.11.2010, 19:40
This one. :banghead:
tomac1975
Postby tomac1975 » Sat 27.11.2010, 19:42
presumably you just pull this apart??
tomac1975
Postby dapinky » Sat 27.11.2010, 20:26
If it's the bobbins that are a bit difficult to get to, then you will notice a couple of holes in the door half way up - usually filled with a rubber grommet - with the window in the right place, they allow a normal screwdriver to get to the bobbin screw :wink:
To get the glass out, it is far easier if you remove the rubber strips first (self tapping screws and pop rivets), as they will need to come off anyway to swap them over (unless they're already on the other door), but with them in situ, its a bugger to get the glass into the runners - with them out, it's a piece of proverbial - take it from a man who spent ages trying to do it without, then had an epiphany :roll:
I had to completely strip the donor door to spray it, then use all the bits off the old one - I'm sure i could save hours on the job by doing it in a different order another time - but it is fairly straightforward - and don't believe anyone who tells you the motor HAS to be fitted before the glass - it can go in afterwards - just a little fidly, but overall, the easiest way (IMHO).
Postby Specky » Sun 28.11.2010, 11:00
tomac1975 wrote:Hi,
Cheers,
Tom :D
I'm not sure if anyone has answered your question per say.
Firstly I agree with DaPinky, That's the method that works for me. :-D
My top tips.... when working on the door windows...
Have electric power available, be it from the car.... or if working in a workshop have an external battery available.
Drop the window down so you can easily remove the butterfly plastic C-clip, chances are the loop will have broken, so ideal to grab with a pair of pliers.
remove the butterfly, now you can manipulate the window eleclectrically up and down, this will allow you to remove the window off the butterfly stud.
Manually pull the window fully up
Remove the motor
This will now give you loads of access to the bobins and the removal of the window as DaPinky says.
Postby tomac1975 » Sun 28.11.2010, 13:43
Thanks pinky and specky have now got the window out ok.
I did need to power it down, being able to see the bits made it easy, luckily the plastic clip stayed in one piece.
now for the locks these look harder any advise on these please.
Then the task of putting it all back together. hopefully before tomorrow.
tomac1975
Postby dapinky » Sun 28.11.2010, 13:53
When you say locks, do you mean the power locking bit, the actual lock mechanism or the keyhole bit????
Not that it really matters, they are all straightforwrd, if a little fiddly.......
Mostly held in with small torqs (SP?) bits - i think they are T40, but could be wrong - with a couple of phillips screws every so often (notably on the plastic exterior door catch - the bit hidden in the recess with the door closed, that you get to with your fingers to undo the door from outside).
The key barrel is held with a simple 'U' spring clip.
All of the bits come out really easily, and in a logical order. Assuming that you've got this far, and the window motor is out, then it is really just a case of ensuring all the Central locking wires are unplugged, and undoing whichever bit you get to first (I started at the rear end and worked forward, into the recesses of darkness).
It may be worth taking a couple of photos of which way the operating bars/rods run inside the door, although they will only go in one way, it may help to orientate them in front/behind other bits when reassembling. Not all of them need to be removed, just enough to free the unit that is coming out.
I also assume that you have undone the wiring inside the car???? There is a multipin plug (or maybe two) inside the footwell, tucked up behind the dashboard/A pillar and cable tied to the frame - undoing them means the door can come off as a total assembly.
Postby Specky » Sun 28.11.2010, 13:58
What DaPinky said...Edit
It's not that bad...
Take a few pictures as you go for the rebuild.
It's more a case of popping the elbows on the control rods
The door lock allen key bolts are sometimes quite tight
It's a bit of a bugger to get it in and out, it quite heavy for it's size.
but there are no real issues
Postby tomac1975 » Sun 28.11.2010, 14:02
Thanks it came out ok, just wondering what these wires a
re? they weren't connected but not sure if they need to be?
tomac1975
Postby Specky » Sun 28.11.2010, 14:08
I'm not in my normal part of the world, so I haven't got access to my stripped doors, but IIRC the first generation of Elans were going to have remote central locking. so the loom is fitted.
If no one can give you an answer, I can give you an answer next week.
Postby tomac1975 » Sun 28.11.2010, 16:20
Thanks Specky and Pinky for advise, one new (ish) door fitted with working window.
just door card to refit and spray job for the rest of the car to match the excellent job on the new door.
:D
tomac1975
Return to Doors and Windows
