US Windshield - Need to Replace
Postby Peter_W » Mon 22.08.2011, 01:46
I need to replace my windshield - I'll contact the dealer on Monday, but that's usually a shock to the system price-wise. Has anyone sourced one in the US fairly recently?
Peter_W
Re: US Windshield - Need to Replace
Postby lotusgirlmarie » Mon 22.08.2011, 04:22
Dave bean engineering. They should have a few in stock.
lotusgirlmarie
Goddess
Postby Peter_W » Mon 22.08.2011, 17:04
lotusgirlmarie wrote:Dave bean engineering. They should have a few in stock.
Thank you - I just called them and they are available to be drop shipped from their supplier. They also have the trim pieces in stock - top, sides, corners. I also called Pilkington Classics - they also have the windshield available. Both told me it was a Triplex windshield.
Peter_W
Postby steve matthews » Mon 22.08.2011, 20:07
Peter, If I may ask how much.
Mine does have a ding that I imagine will get larger.
Steve
steve matthews
Postby Peter_W » Tue 23.08.2011, 05:06
Steve,
If your ding is currently small enough to be repairable, I'd recommend getting it done now ...
From Dave Bean - windshield $679.80, shipping $180, trim - corners $13 (1 piece cut in half to make two corners), top $38, sides $19 each.
From Pilkington Classics - windshield $535, shipping $110. Before quoting they asked if I was a shop - answer was no, an individual owner. If I go with a shop I would expect they could get it for less.
In addition, the following are needed per the manual the write-up linked below: Betaseal Kit A075B6158J and Mirror Plinth Kit A100B6230S - I'll check on their availability.
A great write-up on the procedure here by saska forum.lotuselancentral.com/viewtopic.php?f=32&t=6529#p231147, and the repair manual has detailed instructions. As the procedure has enough time consuming details, as a careful, takes my time, DIYer I'm tempted to do it myself, instead of trusting it to someone working against the clock. The trade-off would be my willingness to take all the time it needs (but I haven't changed a windshield before) vs. someone who's done it many times, but can't / won't spend the time. I have to say that looking at it again just now, freeing up the bottom of the windshield looks like it would be a cast iron b!tch of a job.
In my case it appears the mirror anchoring location may have been the culprit. The crack starts there (in the inside layer), and spread to both the drivers and passengers side, with a couple lines straight up to the top windshield edge also.
Peter_W
Postby mlewi6 » Wed 21.09.2011, 05:41
My windsheild has just cracked from the rear view mirror. Any other recommendations or suggestios for sourcing and replacing would be really approeciated.
Thanks, Martyn.
mlewi6
Return to Doors and Windows
