by paulsmithmk » Mon 16.07.2012, 21:57
Please can anyone help
I have no central locking in my S2 - have tried some of the tests shown in forum but nothing - as in I hear no noise when I use either lock (I only have a key) could it be a fuse? The car also looks like it should have an alarm - censors on near rear view mirror and red light in central console but nothing works - could the two issues be related??
sorry If I am asking dumb questions - only picked her up on Saturday and have lots to learn!
Many thanks
Paul
S2 Number 640
paulsmithmk
by bobbrown » Mon 16.07.2012, 23:35
If memory cell is working S2's had a fob to actuate the alarm so your missing a bit.
Pacific Blue N/A
by muley » Tue 17.07.2012, 07:05
S2s are a bit different to SEs in that they do not have a CDL module - the S2 relies on the alarm module (I think).
i.e. if you manually lock a door the other lock will only be activated via the alarm module, If the alarm module has been disabled/removed you lose that facility( I think).
I had untold problems with the standard S2 setup. So I had the whole lot replaced and never looked back.
Of course, you might have a duff solenoid in the door lock - I had that, too.
by paulsmithmk » Tue 17.07.2012, 07:20
Thanks think a replacement will be a good idea...
S2 Number 640
paulsmithmk
by MPx » Tue 17.07.2012, 10:24
Yes, our S2 CDL works off the fob, but you can manually lock/unlock either door without affecting the other so CDL is alarm based and not a separate function. If you want to check if you have one, the alarm module should be in the void under what would normally be a parcel shelf behind the drivers seat next to the battery but nearer the side. Sensibly difficult to get at!
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
but no longer Carlton no 808 nor Sunbeam S1
MPx
by addict » Wed 18.07.2012, 15:26
i fitted a cdl in mine as the alarm had been changed works a treat
addict
by paulsmithmk » Wed 01.08.2012, 20:58
new alarm fitted but when they opened her up they found the central locking system had been removed oh well at least she is safe!!
S2 Number 640
paulsmithmk
by Brit-Car-Nut » Wed 01.08.2012, 21:07
Removed????
They took the lock controllers out of each door?
I thought the S2 used the alarm module to control the door locks?
by paulsmithmk » Wed 01.08.2012, 22:16
No idea yet as dont have it back but I couldnt find the alarm unit where it was meant to be also!
S2 Number 640
paulsmithmk
by Brit-Car-Nut » Wed 01.08.2012, 22:21
But the harness connectors should be there and all the circuits for the locks should have been accessable. Lotus even used to have a "generic" harness that plugged into the main alarm plug and gave installer access to the circuits without cutting anything.
Brit-Car-Nut on Sun 04.05.2014, 23:23, edited 1 time in total.
by johnr101 » Sun 04.05.2014, 08:50
My recently acquired 95 M100 S2 had a problem with only one of the remote control fobs actuating the original Gemini alarm unit ( the LED on the remote illuminated, it was transmitting, but no response from the car).
Fortunately the previous owner had kept all the documentation (fantastic, thank you so much!) including the alarm key code card.
It's a 10 digit number normally starting with 42...
Found the number for Gemini alarm distribution in the UK through the forum - 08702 402554 (company called AVS at Clacton).
The proprietor was very helpful. The remotes are not made any more, but he has the kit to test and reprogram them. After a few attempts he was able to reprogram the (two) spare remotes.
Thank you very much AVS (they also supply much newer alarm immobilisers ).
johnr101
Return to Doors and Windows
