Hi guys,
Just started to replace the seals on my car.
It is a Elan S1 1991Because I seriously struggled so far, I thought I would put some feed-back here in case that may be of help to anyone.
Here is the way I managed to do so far:
First read all the following stuff:
The glass has to come out. Several have tried dropping the glass into the door shell but there is always a screw or bolt that gets in the way. You don't have to gut the door, but you will find it easiest if you remove the glass. It has been a long time since I pulled my window glass, but I believe once you remove the door card and gain access to the insides of the door shell, you remove the up-stops from the glass and release the butterfly clip (don't get your fingers pinched as the door tries to go to the bottom of the door shell) and you can gently raise the glass out of the door shell.
There are several write-up on LEC the most common references are the one in the WikiLEC.
Door card removal is here:
http://wikilec.9600.org/index.php/Door_TrimDoor Glass removal is here:
http://wikilec.9600.org/index.php/Door_glassWeatherstrips replacement is here:
http://wikilec.9600.org/index.php/Door_ ... therstrips You don't have to do all of the tab rebuilding, but the process is basically the same otherwise. >> BCN
Now, my additional personal tips with pics:
You will face the following issue: can't access with a screwpull two of the screws which are in a way 'hidden' by the rear and the central window guide channels. How to gain access as follows:
Door Rear end window guide channel:
You will need to 'move' the window guide channel. How-to:
Door central window guide channel:
Use similar solution with the window central guide channel
Now you have taken the old seal off the car and can see how the PNM seal is matching very well:
But as you are already aware, you need to adjust them to your car now (Description below and dimensions may need to be adjusted to your car. Please check as each car can be different...).
Here is how I did, but please take care when using any sharp knife or cutter... That may be fairly tricky and dangerous depending the tool(s) you use:
Seal front end 'How-to'
1- Cut the hard plastic part right at the metal end (do not cut the rubber at this step)
2 - if you can, tear the plastic part you cut of the rubber:
3- assuming you were successfull (without damaging the rubber part), time has come to cut the rubber part:
4- hopefully, you have now a perfect front end seal:
Part II: ...see next post ! (max 10 pics per post
WienLot
