Door Card fastners (bottom of the door card)
Postby localad » Mon 08.07.2013, 17:06
Hi everyone, I need to take off my door card as some of the fasteners to fasten the bottom of the door card have broken do you know where I could get some ?
Andy
localad
Re: Door Card fastners (bottom of the door card)
Postby paulsmithmk » Mon 08.07.2013, 17:08
SJ's has them as I needed some last year but they may have a standard GM part..
S2 Number 640
paulsmithmk
Postby dapinky » Mon 08.07.2013, 17:18
they are a 'standard' sort of part which you should be able to pick up locally - these ones are on ebay, and you just need a standard M6 capscrew if yours are no good.
Postby localad » Tue 09.07.2013, 13:59
Hi David, thanks for the link, I am sure this is a silly question, where do you get standard M6 cap screws?
localad
Postby dapinky » Tue 09.07.2013, 17:10
I have a local 'nuts and bolts' shop which sells loads of options, individually....
...but B&Q and screwfix sell them in packs of 10.
I would expect that you can get them locally to yourself (any hardware shop should have them), or ebay also do 'package deals' with the rawlnuts (otherwise called wellnuts) with the capscrews.
Postby localad » Wed 10.07.2013, 10:04
Thanks guys
localad
Return to Doors and Windows
