Windows
Windows
Postby Stryker » Fri 28.03.2014, 19:28
Hi I have a passenger window that falls at an angle when going down I am about to have a go at sorting it if anyone has come across this fault what bits am I likely to require and any suggestions as to where I might source them I have the orange clips for the door card removal. thanks for any help in anticipation.
H
Stryker
Re: Windows
Postby epipete » Fri 28.03.2014, 19:43
This thread will tell you everything you ever wanted to know about windows:
viewtopic.php?f=32&t=20999&hilit=specky#p266084
Re: Windows
Postby Fredjohn » Fri 28.03.2014, 20:04
Orange clips are readily available from Vauxhall dealership. Only about £2 each. Think the dealership will only supply in batches of 5, so I spent a tenner and keep the spares for future use.
Alternatively I am sure SJ Sports or Paul Matty will have them. See also WikiLEC under "Orange Clip"
Re: Windows
Postby Stryker » Fri 28.03.2014, 20:36
Thanks for help with thread wondering if anyone can advise where I can get sliders and cables if required so as I can have bits to hand
Stryker
Re: Windows
Postby Brit-Car-Nut » Fri 28.03.2014, 20:48
The sliders A100B6210S (RH) and A100B6211S (LH) are still available from Lotus Dealers as wel as SJS and Mattey. 1.45 and 1.40 each respectively. The guide rail slides A100B1097F are available same way for 7.55 each. The Butterfly is A100B6271S is also available for 4.37.
The spacer tube A100B1089K is obsolete but the quantity was reduced or eliminated if I am remembering correctly. Others have used generic thickwall nylon tubing / sleeving of the same diameter to substitute
Re: Windows
Postby Fredjohn » Fri 28.03.2014, 21:18
Further help: on thread quoted above by Epipete two of the pics are links to short videos on removal/replacement of complete winding mechanism. Its the two were the untrimmed door is leaning against a wall preceded by the advice large and red CLICK THE PHOTOGRAPH.
Very very useful and someone should put it in WikiLEC please??
Had to do mine recently as the slider was worn and refused to hold the cable. So can also confirm sliders are still available! Pain of a job but well within the average DIYer. Difficult bit is getting the cable back on, but it is not impossible. Managed on my own, but a second pair of hands would make it a lot easier.
Good luck.
Re: Windows
Postby epipete » Fri 28.03.2014, 23:12
I remembered Specky post when I read Strykers query and looked in the Wiki first. I was surprised it wasn't there and had to search for it longhand. It really is too good to lose and should be in the wiki please!
Re: Windows
Postby Stryker » Sat 29.03.2014, 18:51
Thanks to all I will Order parts required before doing this so as I have them to hand when I get to this in the near future
Stryker
Re: Windows
Postby CallMeLegend » Wed 24.06.2020, 17:19
Can anybody remember the diameter of the spacer tube? I'd be happy to make a batch from a Nylon or PEEK tube/bar.
CallMeLegend
Re: Windows
Postby Brit-Car-Nut » Wed 24.06.2020, 17:38
Re: Windows
Postby Simon_P » Wed 24.06.2020, 17:41
I can't remember the size of the tube but it will more than likely be in place. I have used hard windscreen washer tube in the past - It goes hard if you use it for brake bleeding. It needs to be slightly flexible as it is taking the slack out of the guide that's why it ends up oval.
Having done this recently
- Rather than completely removing the metal strip, remove a couple of rivets and carefully bend the end out of the way
- often it is the rubber washers that have perished and the spigot becomes loose
- you will more than likely break the retaining clip on the butterfly
- don't forget to put vaseline on the sliders
- Now is your opportunity to make sure that the window runs freely and fits correctly - see manual for adjustment.
Re: Windows
Postby dapinky » Wed 24.06.2020, 17:43
I can't remember ever knowing the diameter, but about 6 years ago I made some new rollers up out of PTFE rod to the same diameter of the originals.....
.... it didn't work well at all :(
I think it needs some pliability of the material (hence the hollow rollers) to allow both support and to go through the uneven curvature of the rails.
Now, I'm no engineer, and my 'lathe' was a cordless drill holding the rod whilst I turned it down with a wood chisel (but it worked!) .....
.... maybe if they were a tad slimmer, or a different material it would have been better, so with your engineering background, I'll defer to your ability, and I'll order a set :D
Re: Windows
Postby Brit-Car-Nut » Wed 24.06.2020, 17:47
When I put my windows back in, I used 9/32 PTFE rods I got off eBay. It was a good fit and the windows don't rattle and don't drag.
Re: Windows
Postby Simon_P » Wed 24.06.2020, 17:55
Brit-Car-Nut wrote:ninethirtytooths is 9/32"
nah ninethirtytooths is aboot 7.2 mm to a smithy, and 9/32" is 7.14375 mm ....not allowing for the curvature of the earth.
Re: Windows
Postby CallMeLegend » Wed 24.06.2020, 18:14
CallMeLegend
Re: Windows
Postby Arielle25 » Wed 28.10.2020, 05:13
Brit-Car-Nut wrote:The sliders A100B6210S (RH) and A100B6211S (LH) are still available from Lotus Dealers as wel as SJS and Mattey. 1.45 and 1.40 each respectively. The guide rail slides A100B1097F are available same way for 7.55 each. The Butterfly is A100B6271S is also available for 4.37.
The spacer tube A100B1089K is obsolete but the quantity was reduced or eliminated if I am remembering correctly mutuelle TNS. Others have used generic thickwall nylon tubing / sleeving of the same diameter to substitute
It would help us a lot if you put some pictures here.
Arielle25
Return to Doors and Windows
