epipete wrote:I put mine in again yesterday, when you removed the glass did you also remove the inside brush carrier (long metal strip riveted on top of the door) and undo the boys holding the support pads?
I always have the same problems as you describe but find that a bit of gentle leverage and easing at the lock end helps.
Perhaps a little bit of friction is OK.CalElan wrote:has anyone got any tips beyond - 'fitting is the reverse of removal'?
I can get the glass to slide in at the front but can only get as far as the bottom slider on the rear - it feels like it's totally jammed - but i can't see anything!
Help!
