by bbjon » Wed 18.04.2018, 08:47
Hi all - I've got an odd lock problem - it seems the opposite to things that most of the posts I've seen. Ok
The locks work fine using the buttons in the door - they open and close as they should
The locks don't work with the key - turning the key in either the passenger or drivers lock results in nothing - there isn't any resistance behind the key at all stop to stop
Before I start stripping the doors down again - is this a problem anyone recognises?
bbjon
- Tinkerer
by RonR » Wed 18.04.2018, 09:23
Jon,
I saw in another post that you've recently had a respray, did the sprayers take the key locks off?
If so, they could have forgotten to reconnect them - the rods clip into a small nylon fitting - A100B6037F item 5 on page 10.17a of the parts book, available from SJ if they got lost or damaged like one of mine was.
The good(ish) news is you don't have to take the glass out to reconnect them.
by bbjon » Wed 18.04.2018, 12:13
Hi Ron - I'll check it out - I was sure I'd locked the car since getting it back but maybe not. Preparing to hit face with palm!
bbjon
- Tinkerer
by bbjon » Tue 01.05.2018, 09:48
Finally got to look at this and.... I'm a numpty the guys who did the respray had failed to reconnect the rods.
Rodded now and repaired.
cheers
bbjon
- Tinkerer
by Rambo » Tue 01.05.2018, 12:18
Well done RonR
- Don't push me
Return to Doors and Windows
