by Rice crispy » Mon 26.04.2021, 18:21
I think my passenger door center slider is about to give up as it stops when closing the window as the rear isn't closing as fast as the front. I know how to strip the door and get the motor out and have the slider and butterfly to replace if needed but wondered if I will need to re-spool the motor when I release the cables to swap the slider or if its more simple and they will stay in place. I know it can be a pig to get the cables onto the pulleys and I need 3 hands.
Rice crispy
by HJ2 » Tue 27.04.2021, 19:50
It is more simple
You'll see it when you have the assembly in your hands. Keep the tension on the cables and you can replace the center slider without rewinding the cable.
Replace all sliders and grease while you are in there!
by Rice crispy » Tue 27.04.2021, 20:00
Thank HJ2 was thinking of trying to clamp them lightly to stop them unravelling
Rice crispy
by HJ2 » Tue 27.04.2021, 20:14
That’s what I did.
There is a spring and with a little elbow grease you can get the cable ends in the center slider replacement!
by Rice crispy » Tue 27.04.2021, 21:00
HJ2 thanks very much
Rice crispy
by HJ2 » Tue 27.04.2021, 21:42
I can take a picture tomorrow if that helps (my old center slider assey)
by Rice crispy » Tue 27.04.2021, 21:45
That would be great thanks
Rice crispy
by HJ2 » Fri 30.04.2021, 20:09
Sorry, I could not find the complete slider assembly,
But here is the winder assembly:
And here's the slider:
But it is pretty straight forward once you have everything in front of you.
Good luck!
by Rice crispy » Fri 30.04.2021, 20:29
Thanks very much. I'm going to have a go next weekend
Rice crispy
Return to Doors and Windows
