by DeanG » Wed 20.09.2006, 01:00
OK the passenger side window won't go up (1991 Federal car). It had been an intermittent problem for a while, but now it is stuck down. I swapped the relays and the switch to no avail. I used to be able to wiggle the relays and it would work for a short time. That trick no longer works. Any ideas?
DeanG
by Ekapol » Wed 20.09.2006, 01:18
Is the motor still working? Do you hear the motor noise when you switch up/down?
If motor is good. There are 2 options you can pick from:
1) Butterfly Clip
2) Cable snapped
HINTS: Don't pick #2
Ekapol
by DeanG » Wed 20.09.2006, 01:28
It is definately electrical. I had issues with the windows in prior years. I have had to replace the butterfly (both sides) and the motor-cable assembly on the one door.
DeanG
by tigerdog » Wed 13.06.2007, 00:17
DeanG wrote:OK the passenger side window won't go up (1991 Federal car). It had been an intermittent problem for a while, but now it is stuck down. I swapped the relays and the switch to no avail. I used to be able to wiggle the relays and it would work for a short time. That trick no longer works. Any ideas?
How did you resolve this problem, DeanG? If it was anything other than parking the car when raining, please let me know.
I bought my BRG Fed Elan on Saturday. On Sunday, the window up became intermittent. Today, the window is down.
HOORAY! I own a Lotus.
I've swapped the switches - relays are next.
by Doug » Wed 13.06.2007, 01:13
time to learn how to open the dorr up and see what's up
check out Ekapol's threads on the window fixes . . . .
- LEC Founder
by Ekapol » Wed 13.06.2007, 01:22
tigerdog wrote: HOORAY! I own a Lotus.
Congratulations Tigerdog. You've just proofed the authenticity of your Elan. Excellent !!
WINDOW MOTOR CLICK ME!-------------------
Also HERE!-----------------------------
And HERE!-----------------------------
Ekapol
by tigerdog » Wed 13.06.2007, 02:09
Where the frakk are the relays? Not behind the instrument panel, I see. I can hear the emergency flasher relay but can't figure out where Lotus have stuffed the relay block on my Fed Elan.
by tigerdog » Wed 13.06.2007, 03:22
...then
feel the love, er the relays. Swopped them about, problem moved. Change back, problem disappears! Chock this up to
-intermittant relay
-corroded contacts
-Colin Chapman's ghost playing games with a newbie
I'm assuming the latter. Onward and upward! I am incredibly thankful for this forum and its members. And hey, I'm just beginning!
by tigerdog » Wed 13.06.2007, 08:01
tigerdog wrote:Swopped them about, problem moved. Change back, problem disappears!
Ironically, my rank changed from "newbie" to "tinkerer" with this last post.
by GeoffSmith » Wed 13.06.2007, 20:10
tigerdog wrote:tigerdog wrote:Swopped them about, problem moved. Change back, problem disappears!
Nice one StripeyDoug
- Kitty Fiddler
by tigerdog » Wed 13.06.2007, 21:14
geoffsmith wrote:Nice one StripeyDoug
But my Elan isn't stripey... you're just messing with an old dog, aren't you?
by GeoffSmith » Wed 13.06.2007, 21:51
tigerdog wrote:geoffsmith wrote:Nice one StripeyDoug
Tiger changes his spots?
- Kitty Fiddler
by tigerdog » Fri 15.06.2007, 05:52
Tigerdog == StripeyDoug
I just understood the reference!
The "stripey" part confused me; I didn't think of tiger stripes as in the animal, I thought of LEC Doug's "Stripey Garage Queen" BRG Elan. Tigerdog was our family dog, named (by my dear wife) for the pet in "The Brady Bunch", an popular yet (IMO) unfortunate TV sitcom. He grew more grizzled and cantankerous with each passing season. Since I'm doing the same, I adopted his visage and moniker for my web presence.
by DeanG » Fri 22.06.2007, 21:23
The electrical problem that was intermittant was due to a bad connection. The wierd part was that the voltage readings betwen the up and down side of the wiring were not very different. I finally figgured it out by jumpering the window directly to the battery. It would go both directions. Swaping the wires on the switch didn't solve the problem, neither did swithcing the relay's. Playing with the fueses didn't help. I eventually cut off the connectors and replaced them.
DeanG
by tigerdog » Fri 22.06.2007, 21:55
Thanks, DeanG. Thankfully my problem was simpler than yours to diagnose/fix.
Return to Doors and Windows
