Engine Hesitation
Engine Hesitation
Postby Wortho » Thu 17.10.2019, 11:52
I have a 1990 SE with 70,000 miles only mods are a Miltek exhaust and an Alpha air filter.
Yesterday the engine started to hesitate when accelerating under load from around 3500 RPM the only other symptom i can find is a slight rattle from the CAS.
Elan Scan gives an error code of 4000 but I cannot find anything that corresponds with this on WikiLEC.
Anyone any ideas please?
Lotus Elan SE 1990 x 2, Porsche 911 C4S, Mazda MX5 NA, Mini Cooper RSP, VW Scirocco, VW Golf TDI.
Wortho
Re: Engine Hesitation
Postby John_W » Thu 17.10.2019, 15:41
I recommend checking:
  • plug gaps
  • static timing is correct and not wavering
  • HES
  • Plug leads
  • Coils
But it sounds like plugs to me, which is the simplest and cheapest of the above.
Postby GeoffSmith » Thu 17.10.2019, 16:30
Pretty sure error code 0x4000 is wastegate related. Open out the fault codes to see what the individual flags mean - press the [+] next to Faults and see which flag is set ON.
PS I had a similar problem just before it went to bed for the winter (but did not scan it) and I suspect I have a sticking wastegate.
Postby Wortho » Thu 17.10.2019, 17:07
Thanks I’m away with work for a few days, I’ll start investigations when I get back.
Wortho
Postby Wortho » Thu 24.10.2019, 16:23
Plugs swapped no change. Waiting for new leads to arrive.
I have opened up the errors on Elan Scan (thanks Geoff I didn’t know how to do this) item 14 Wastegate over boost is on.
I have just “enjoyed” doing the wastegate wiggle with the turbo and heat shields in situ the bottom bolt is a sod to get back in for sure! Everything feels free and I have lubed it up with copper slip.
How do I clear the wastegate fault on Elan Scan please?
Wortho
Postby John_W » Thu 24.10.2019, 16:56
Disconnect the battery to reset fault codes.
Did you set the new plugs to the correct gap? If not, they will still cause a misfire when the turbo kicks in.
Postby Wortho » Thu 24.10.2019, 17:41
Hello John
Yes the gap is set at .8mm.
Wortho
Postby Wortho » Thu 31.10.2019, 17:52
Now sorted! :D It was a dodgy coil pack.
The waste gate over boost error is a separate problem, I think I may need to port the wastegate or adjust the rod (mine has an adjustable actuating rod) so that it opens earlier.
Thank you for your help gentlemen.
Wortho
Postby John_W » Thu 31.10.2019, 21:24
:smt023
Glad you're sorted.
It can sometimes take a while to locate the reason for a problem like this, but you did it pretty quickly. I hope it wasn't too expensive!
Return to Engine
