lotusflasherman wrote:Sounds like you are making progress but now you've got the satisfaction that it runs I think you should move the cambelt change to the top of your 'To do list', ahead of MOT. Standing for 6 years is not good for the section of belt wrapped 'inside out' round the tensioner pulley. I left an Eclat with a new belt for 3 years and 300 miles after I started using it again it lost the teeth over that section, cam timing slipped on the smooth section and 16 valves got bent ...![]()
Must be one of the easiest belts to change too!
s1ghthound01 wrote:Out of interest, there is a fitting coming off the plenum box which is connected to a small bore plastic pipe on the left hand side of the plenum. This has snapped off at the elbow. What is it's purpose and are they available. I have it stuck on with superglue for now, but don't know if this will be successful or not. Any thoughts.
s1ghthound01 wrote:Ok, so now she is running fine and the rear brake calipers fitted, I thought I would get the brakes bled by using the Mrs to pump the pedal. After several failed attemps, I now have a good brake pedal which stops all four wheels pretty well and a working hand brake, my only problem being the offside front sticks on. The seals are in a mess, and so are the slides. As far as I can recall this was the issue the PO had with her when she went off the road six years ago. So, going by previous post on here, it looks like MK11 Astra's are the same, so I have ordered up a new set at only £50 the pair with an agreement from the suppliers that if they don't fit they will take them back for a full refund. Now just too wait on another delivery of parts.
s1ghthound01 wrote:OK so for the past week I have been busy sorting out brakes. New calipers fitted to the rear and rbuilt ones on the front all with new pads of course. Got the chance to get her up on my neighbours ramp the other day so the underside all cleaned of surface rust and flaky bit's and given a good coat of paint. So this morning after a final bleed, of she went for and MOT and low and behold she came home with one, and no advisories. Happy Bunny. Next step is the paint shop on Monday to have the bonnet, rear spoiler, tops of the front wings and the front bumper painted all because of peeling lacquer.
A great success for an abandoned little M100.
Hate to see it all end in tears....
