setting timing and idle
Postby GeoffSmith » Sat 13.01.2007, 02:12
Mick,
The reason I asked about the heater was that, if the thermostat is permanently stuck open, the coolant will generally be on the cool side and therefore the heater runs cooler. I know the Elan heater is not the best there has ever been, but if your coolant is only 60°C rather than 85°C, the heater will be piss poor.
I reckon if you change the thermostat, you'll cure the variable tickover AND improve your heater.
Geoff
Postby mickmick » Sat 13.01.2007, 02:15
gonna take a trip down to the local isuzu dealer tomorow morning then or failing that just find a motor factors type place to get one, if nothing else it'll teach me a few more little things about what is where and how its out together
Cheers again Geoff
Mick
now i have one, i just want to keep tinkering with it!!!!!!!
sorry mum :(
mickmick
Postby Enright » Sat 13.01.2007, 10:16
I might have a bash at my thermostat too - didn't I read somewhere (possibly in the "Part Cross-Reference" section) that it's an off-the-shelf item shared with another common vehicle?
Edit: Found it here!
Postby mickmick » Sat 13.01.2007, 12:51
yeah, i found that link too
now, does anyone have any idea where the gasket can be sourced from???
Mick
sorry mum :(
mickmick
Postby Enright » Sat 13.01.2007, 23:30
What, you mean the gasket for a thermostat housing? Oh I never buy those - just get a sheet of gasket paper, trace round the housing and cut to fit. Maybe use a light smear of Hermetite or Blue Hylomar. It's never let me down yet.
Postby Elantastic » Tue 13.03.2007, 16:31
correct me if Im wrong but could the low heater temperature be down to a dodgy water pump if the fins have corroded on the pump the water from the engine probably wouldn't even get to heater?
Elantastic
Postby mickmick » Tue 13.03.2007, 16:34
thats posible, but since i changed my stat my heater now works and the gauge reading pegs right on the 1/4 mark now
sorry mum :(
mickmick
Postby Elantastic » Tue 13.03.2007, 16:39
Thats a releif those water pump changes look like a nightmare!! Glad everything is working ok!!
Elantastic
Postby muley » Wed 14.03.2007, 00:09
The Halfords jobbie (HTK602) - which fits the M100 - has five gaskets included with it - one of them fits perfectly.
Return to Engine
