IMHO the lotus gasket doesn`t compress that much hence why you don`t need to recheck the head bolts.
Monty wrote:IMHO the lotus gasket doesn`t compress that much hence why you don`t need to recheck the head bolts.
Breed wrote:Dont know if its any help but Piper exhausts have a gasket making service by an american company and they will quote from a sample. They will also change them to meet your specifications. So if anyone has a original to lend them to get the quote it may be that it could be a source for a ongoing supply. The contact at Pipers for the gaskets is Peter and he is in the same office as the exhaust guys so the contact number is the same. When I spoke to them they said that to get it to about $40 dollars a gasket they would look for a order of about 10. Can't do any harm getting a quote but I do not have a head gasket to send them.
Bill
GeoffSmith wrote:That's why I couldn't find it - cunningly concealed in a "Valve Stem Oil Seal Replacement" thread!
bobbrown wrote:Monty wrote:IMHO the lotus gasket doesn`t compress that much hence why you don`t need to recheck the head bolts.
So what is the thickness of a NEW genuine gasket?
lotuska wrote:Firstly I checked the thickness of each head gasket using my trusty micrometer...
Thickness of gasket material
- Lotus Original 1.22mm
- kmckmcs replacement 1.65mm
Thickness of "metal" bits around cylinders etc
- Lotus Original 1.35mm
- kmckmcs replacement 1.75mm
Monty wrote:I could only do mine with digital calipers![]()
Few approx measurements of Turbo Head Gaskets:-
Dico`s old USED stock HG (Silver)
Thickness- 1.21mm cylinder ring (Crushed)
Bore 80.8mm
Dico`s New aftermarket replacement AJUSA (dark grey)
Thickness- 1.28mm Material
Bore 81mm
Kmckmc`s HG (Black)
Thickness- 1.70mm cylinder ring
Material 1.65mm![]()
Bore 81.2mm
bobbrown wrote:While having a little trawl on the internet I did find this little gem and it is worth noting.
"PLEASE NOTE: The 4XE1 DOHC 1.6 liter Non-turbo, 4XE1 DOHC 1.6 liter Turbo, use DIFFERENT PATTERN HEADGASKETS. Water flow through the block is controlled by the shape and size of the water jacket openings in the head gasket.
Using a 1.6 liter Turbo on a 1.6 liter Non-turbo engine will result in engine temperatures too low for the oil to properly lubricate the engine, resulting in rapid bearing wear and engine failure.
Using a 1.6 liter Non-turbo on a Turbocharged engine will result in inadequate engine cooling, overheating, oil breakdown and lubricant failure, head warpage, cracks in the engine's water jacket, and destruction of the engine."
Which explains why there are two different head gaskets, modifying the gasket where the water ways are could be detrimental.
Also the part number for some of the aftermarket head gaskets is the same for the non turbo and the turbo engines, so it may they have not got the cooling quite right and this may lead to head gasket failure.
