Head gasket failures - why so many?
Postby GeoffSmith » Sat 05.04.2008, 21:57
There seems to have been a lot of HGF just recently. I don't know about anyone else, but I'm worried that there are more than you would typically expect. Some things that may be relevant are:
1) People have been tracking their cars, which may put more strain on the engine than you would get under normal everyday driving conditions.
2) A lot of mechanical and electronic performance enhancing equipment has been added, particularly to increase turbo pressure.
Personally, I suspect that cooling may be an issue as the Isuzu engine appears to be pretty solid (unlike, say the Rover K series engine where a head gasket is as essential as a spare wheel). Some of the likely culprits are as follows:
a) Insufficient/old antifreeze causing corrosion resulting in blocked water channels and reduced radiator efficiency.
b) Insufficient/old antifreeze level causing coolant to have a lower boiling point.
c) Cheap aftermarket thermostats sticking.
d) Insufficient/old antifreeze level causing thermostats to stick through build up of corrosion.
e) Stuck thermostats (I have diagnosed quite a few from ElanScan runs) causing coolant to overheat (particularly in stationary traffic).
f) Failure of cooling fan switch causing coolant to overheat.
g) Failure of cooling fan(s) causing coolant to overheat.
h) Defective radiator cap (can’t hold pressure) resulting in lower boiling point.
i) Coolant boiling off resulting in reduced coolant level.
j) Incorrectly bled cooling system.
The bottom line is that a lower coolant level and / or less cooling efficiency can cause localised heating in the head (usually around the exhaust valves as these are naturally the hottest area) resulting in failure of the head gasket. The onset of HGF can result in the cooling system becoming pressurised, blowing off more coolant and making matters worse.
Could people who have experienced HGF start a list of any relevant information to see if there is a trend anywhere?
Geoff
Postby andyhaworth » Sat 05.04.2008, 22:06
I asked one of the chaps at Peter Smiths recently, as I've noticed a few posts popping up with the same theme (and getting ever more worried about mine)
He reckoned it starts with small oil leaks, then water leaks which arent apparent. Think cam seals and a split hose kind of thing.
I dont think the Elan is more prone to it than other motors, I've had a head gasket fail on a CVH with very little warning that cracked the block.
I do get concerned about the temperatures the engine runs, and prolonged periods of boost, especially higher boost with matched revs arent going to make a problem any better
Its 20 year old metal when all's said and done though
andyhaworth
Postby Enright » Sat 05.04.2008, 22:08
Nice idea Geoff - pareto analysis.
Perhaps it might also be worth asking for the mileage at which it went, if a skim was necessary, which piston/s blew, and the exact position of the failure. We may find a common weak point.
Postby chris.t » Sat 05.04.2008, 22:22
may not be relevant but the higher the concentration of anti freeze the lower the specific heat capacity of the coolant.
Postby Monty » Sat 05.04.2008, 23:12
Think the main reason is the age of the cars/gasket and obviously made worst if the coolant isn`t changed regular, think 17 years for pinky isn`t bad going.
There`ll be owners out there that have HG problems and don`t even realise it, i believe now that Pinky II might of even had the beginning of a HGF before i got her. But once you take them on track thats when it`ll show as your on constant boost.
Postby chris.t » Sat 05.04.2008, 23:16
Monty wrote:Think the main reason is the age of the cars/gasket and obviously made worst if the coolant isn't changed regular, think 17 years for pinky isn't bad going.
There'll be owners out there that have HG problems and don't even realise it, i believe now that Pinky II might of even had the beginning of a HGF before i got her. But once you take them on track thats when it'll show as your on constant boost.
So what you're saying is Monty is get a block test/compression test done now before you get an exploding elan :?
Postby Monty » Sat 05.04.2008, 23:25
So what you're saying is Monty is get a block test/compression test done now before you get an exploding Elan :?
You could do, especialy if you get signs of to much pressure in the coolant. But TBH i wouldn`t worry to much unless you do get serious signs as cars can run for years with people not even knowing, but if your into trackdays then thats a different story.
I mean I even manage to drive all the way from bedford over a 3 hour drive with loose head bolts at 70mph :shock: and the temp just about held :? It`s not something i recomend thou :lol:
You can get a block test off ebay so you don`t even have to go the garage to get ripped off :wink:
Postby chris.t » Sat 05.04.2008, 23:38
The thing about HGF is that it get to a serious point before you know it.
Postby texas2201 » Sun 06.04.2008, 09:56
I drove mine all the way from Folembray in France to Berkshire with a HGF - just kept an eye on the water level - the Hall sensor also went
But the garage said everything was fine when we stripped it down and did the repair - replacing all the reccommended bits at the same time - idler, cam belt, etc etc etc
running well now and did Donington track day with no problems
Postby M100 TWO » Sun 06.04.2008, 18:37
good antifreeze a must and change yearly, as a precaution put in Water Wetter, for the first 8 miles keep the revs down to 2.5-3 thou until the oil has warmed up this is a good habit to get into, and have all the fluids at the right level do this and you should not encounter head gasket failure
diff
M100 TWO
Re: Head gasket failures - why so many?
Postby rip » Mon 07.04.2008, 09:07
GeoffSmith wrote:Could people who have experienced HGF start a list of any relevant information to see if there is a trend anywhere?
A few comments, but no list started yet. Ok, I'll start one then.
This was the cause of mine. A previous owner had apparently run it with a very low (maybe zero) conc of antifreeze.
Killed of both the rad & head gasket. Went almost together, but I suspect one killed the other. I think it was like a silent timebomb, just waiting for the most embarassing moment.
Head needed skimming by 8 thou.
Now running on 40% antifreeze, as recommended by Gerald at GST Performance.
chris.t wrote:So what you're saying is Monty is get a block test/compression test done now before you get an exploding Elan :?
One EE is enough. We don't want any more.
Postby Rambo » Mon 07.04.2008, 11:07
I also think there have been an unusually high no. of these recently - I can think of about 6 in the last few months and there are others that have posted symptoms that are synonymous with HGF.
I've just started suspecting something not quite right with mine - the pink anti-freeze (40%) seems to have slight traces of an oily deposit but perhaps its gunk from the thermostat housing that's worked its way into the header tank as I have just changed the thermostat recently. I'm also losing coolant but I suspect I have a loose connection and/or a split hose.
Call me paranoid but I'm going to arrange a block/compression test asap
PS Slightly :offtopic: but there are also an unusally high no. of alternator failures but perhaps that is not too surprising in a 16/17 yo car ?
Postby rip » Mon 07.04.2008, 13:33
Rambo wrote: the pink anti-freeze (40%)
I was advised not to use this because it is methanol-based, not ethylene glycol like the blue/green stuff.
Maybe somebody can explain how they react differently.
Google time.
Incidentally, Ethylene is an old chemical name. Surely we should now be saying Ethene?
EDIT - Ehtylene Glycol is now correctly called ethane-1,2-diol
Postby rip » Mon 07.04.2008, 13:59
Was thinking about posting this elsewhere, but I think it is related to possible HGF.
Somebody on another website wrote:For many years, since the demise of Methanol based antifreeze that was traditionally only added just before winter, blue/green or yellow Monoethylene Glycol (MEG) has been the mainstay of the coolant market. However Ford vehicles since 08/98 have been filled with coolant combining Monoethylene glycol with Organic Additive Technology (OAT) corrosion inhibitors.
There are important differences between standard MEG and MEG with OAT. It does not contain silicates, nitrates, nitrites, borates, phosphates or amines so that:
· Without silicates, silicate gel or "green goo" does not form.
· By eliminating phosphates, hard water scale is reduced.
· Without silicates, phosphates, nitrates, nitrites and borates, abrasive dissolved acids are greatly reduced thereby diminishing water pump seal failures.
· Without amines and nitrites, there is no potential formation of nitrosamines.
All of this results in a considerably longer life span, whilst providing improved protection of all cooling system metals, including aluminium. Benefits over conventional silicate based coolants are:
· Improved water pump life due to reduced water pump seal wear.
· Fewer abrasive dissolved solids.
· Reduced hard water scale.
· Virtually no deterioration of heat transfer capacity during service life.
· Excellent protection against high temperature and pitting corrosion.
· No silicate gel formation during storage or use.
· Effective long-term corrosion protection for aluminium, brass, cast iron, steel, solder and copper alloys.
· Long effective service life of up to 10 years or 150,000 miles.
The two types of coolant should not be mixed. Vehicles filled with MEG will have coolant coloured blue, green or yellow. MEG with OAT additives will have coolant coloured Orange (Ford) or red.
Ok, so my previous post appeared to contain out of date info.
Also:
Somebody else on the same other website wrote:I drained and flushed my old Sierra the other year only to find that Halfords had only the "new super stuff" in stock.
I used that and have had no problems. I have a slight leak so when I came to get another bottle of the same stuff they had changed its colour to pink.
I know it is the same stuff as I have the original bottle and it is much more expensive.
So bottom line is do not trust the colour.
Only sure way is drain and flush and start again
So there you have it. Whatever you have got in there, don't mix it with something different. If in doubt, drain it out & record what type you use.
& if it doesn't say on the bottle, don't buy it.
I did not fill EE (was done recently at a Garage), so if & when it needs topping up..I'll flush it to make sure I don't mix. I don't want an "Exploded Twice" Elan.
What I did not find was if it is ok to use the OAT stuff in older engines. I'll use the MEG stuff in EE then.
Postby dapinky » Mon 07.04.2008, 18:43
rip wrote:a) Insufficient/old antifreeze causing corrosion resulting in blocked water channels and reduced radiator efficiency.
b) Pretty much the same as above - low coolant level whilst stored by previous owner, low conc of antifreeze, solidified gunge in head. Unable to say which went first (and caused the other?) - HG or Rad.
Also Thermostat stuck open.
Head skimmed by 9 thou.
Now running RED antifreeze :-D (It's the new stuff, not old red stuff, and has a 5-year life) expensive, but cheaper than a HGF!!!
Postby Dico » Mon 07.04.2008, 20:54
Pinky, I've seen the lifetime antifreeze/coolant advertised and wondered if it was a bit of a gimick (not that I have any knowledge). What make is the stuff you used?
Postby dapinky » Mon 07.04.2008, 21:13
Dico,
Made by 'El-Cheapo' and bought from 'Gimmics-R-Us'!
Okay, then, Its Carplan Premium Red, and I bought it at Maccess.
Postby rip » Tue 08.04.2008, 08:55
So Dapinky & I both had HGF caused by "Antifreeze abuse". Nothing to worry about as long as you look after your coolant (Which oprevious owners of both our Elans apparently did not.
I am still looking into Anti-freeze. Althought it is HGF related, I am going to start another thread in the Engine Ancillaries section (after checking that such a thread does not already exist ;-) ).
Postby chris.t » Tue 08.04.2008, 12:27
ok i'm getting confused now. I am having my rad changed in a weeks time. What A/F should i be putting in it.
Cheers Chris
Postby rip » Tue 08.04.2008, 13:32
I've done a bit more research on this, and started .this thread, just to stop this one going off-topic, but this was felt unappropriate.
If your new radiator is Aluminium, you can use the 5-year (red/pink) stuff with the organic corrosion inhibitor.
If not, use the silicate (blue/green) stuff & change every 2 years as normal.
The red stuff does not inhibit copper/brass corrosion.
Just a thought: are there any other brass items in the cooling jacket, ie temperature sensors? If in any doubt, I would stick to the silicate stuff.
& don't think that "organic" means enviromnentally friendly or anything. It simply means carbon/hydrogen-based chemical.
Return to Engine
