remove crankcase ventilation valve fitted in cam cover?
Postby raphsolo » Sat 03.06.2017, 13:52
Hello !
My crankcase ventilation valve (fitted in cam cover) is broken in the middle...
But i can't remove the part in cam cover ???
How to do it ?
Thank's a lot !
Lotus Elan M100 turbo SE 1991 racing green - Lotus Elise S1 azur blue
raphsolo
Re: remove crankcase ventilation valve fitted in cam cover?
Postby Simon_P » Sat 03.06.2017, 17:22
It's just a plastic pipe with a rim (like the other end) pushed into a rubber grommet.
Put a screw or hook up the middle and pull it out.
Postby lotusflasherman » Sat 03.06.2017, 18:41
Simon_P wrote:It's just a plastic pipe with a rim (like the other end) pushed into a rubber grommet.
:agree: probably the grommet has gone hard as rock and won't let it go so needs cutting off and replacing... sharp chisel and big hammer job .. Wham bang, job done ... :lol:
Postby HJ2 » Sat 03.06.2017, 22:37
... thank you ma'am :bananasex:
Postby raphsolo » Sun 04.06.2017, 16:54
Yes...very hard...so i need to cut it....but it's plastic tube inside a plastic part !
THere is a plastic part on the cam cover, the crankcase go inside...is it possible to get out this plastic part ?
Thank you !
raphsolo
Return to Engine
