Over Boost?
Over Boost?
Postby Dom » Sat 28.10.2017, 21:25
Evening, All.
I recently fitted a PNM exhaust. Since then, I seem to be suffering from overboost as it’s like I hit a brick wall at full throttle and high revs. The CEL shows, then goes out. It didn’t happen before the new exhaust.
The car is well maintained and had a service very recently, including new plugs. I have done the waste gate waggle, too.
So, how do I overcome this problem?
Many thanks,
Dom
Dom
Re: Over Boost?
Postby par » Sat 28.10.2017, 22:41
Definitely sounds like overboost which is apparently common when more free flowing exhaust is fitted. This is usually overcome by porting the wastegate, there is a link in WikiLEC which covers the details:-
wikilec.com/view/Porting_the_wastegate
The guide suggests porting to 20mm but I had mine increased to 21mm which solved the problem for me.
par
Re: Over Boost?
Postby rip » Sun 29.10.2017, 08:46
This is not a design fault.
The wastegate would have been designed to control boost by opening/closing fully with the standard exhaust. Now you have increased the exhaust flow, the wastegate needs to be open more than 100%, which is impossible. The only way around it is to make it bigger by porting it.
I have read a lot of comments about "like brakes came on" / "like hitting a brick wall".
Even without looking at the boost gauge, you know when you are getting close to overboost. The car hesitates before the fuel cut kicks in, giving you plenty of time to lift off.
Re: Over Boost?
Postby Rambo » Sun 29.10.2017, 09:55
Porting the wastegate should sort the problem of overboost as par and rip have stated
Re: Over Boost?
Postby Steve A » Sun 29.10.2017, 12:35
If you search the forum this subject is well documented, even I've had it at one time due to messing with the exhaust,
porting was the answer, not a 5 minute job but if you want to go faster you have to pay the penalty :wink:
Re: Over Boost?
Postby V8vroom » Sun 29.10.2017, 15:16
It’s trying to find someone somewhere who understands AND is willing to port it for you! 2 lotus experts near me deny the problem exists !
Lotus Elan S2 No. 513 Norfolk Mustard
V8vroom
Re: Over Boost?
Postby Dom » Sun 29.10.2017, 16:30
Thank you for your suggestions. Yes, I’ll have to get the wastegate ported, by all accounts. I don’t have the facilities to do it myself, so it’s a job for a garage. I’ve got Lakeside Engineering and Steve Williams near me, so I’m lucky in that respect. I’ve never used Steve Williams, but have heard good things.
Dom
Re: Over Boost?
Postby Steve A » Sun 29.10.2017, 17:57
:D It's best done on a milling machine which any toolroom will have, just find a good one.
Return to Engine
Users browsing this forum: Google [Bot] and 1 guest
