ElanScan Interface
Re: ElanScan Interface
Postby JusNoGood » Fri 11.05.2018, 14:01
Hi Geoff,
Thanks very much for the cable. Received it some time ago but just been too busy on the car!
I've read the wiki but the link on there seems to link to a Win98/2k and no mention of XP (looking at the readme and also trying to install using the VCP folder and I get no drivers present). Do you have a link to the XP drivers please?
Justin
JusNoGood
Postby Fredjohn » Fri 11.05.2018, 15:58
Justin
I've used Elanscan on XP, Vista and 10 with no driver problem (other than the one behind the wheel).
Load Elanscan and just try a driver update in the control panel/programmes area.
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Postby JusNoGood » Fri 11.05.2018, 16:12
Fredjohn wrote:Justin
Unfortunately it tries to install the driver, doesn't find it, and then there is an error entry in the device manager. If I click on upgrade driver it doesn't find it, even if I point it to the VC file.
JusNoGood
Postby Dazzle » Thu 28.06.2018, 00:34
Hi Geoff,
Do you have any interface cables available as I would like to purchase one, thanks.
Scratch that decided to have a go and make one up :-?
Dazzle
Postby GeoffSmith » Sat 22.09.2018, 14:37
A few people asked while I was in Spain…
I now have a couple more USB versions built up if anyone is still after one. Be warned, I'm almost out of pcbs and ALDL plugs, so it's pretty much the end of the road as re-stocking/buying singly is prohibitively expensive.
Postby a5gcd » Sat 29.09.2018, 20:00
Hi Geoff
This doesn't work for me either.
Can you tell me how to get the drivers for your original USB interface to use it with Windows 10. I can get the PC to recognise the device but I cant update the drivers.
Geoff D]
a5gcd
Postby peteric » Mon 01.10.2018, 13:54
Hi Geoff
I would like a cable please.
Peter
peteric
Postby scubasteve » Tue 09.10.2018, 11:34
GeoffSmith wrote:A few people asked while I was in Spain…
Hi, I'm new to forum and new to owning an m100. bought it with a problem though 'cos I like a challenge.
car won't run over 3000rpm and I have no eml on dash (doesn't illuminate when ignition turned on - suspect bulb removed to get it through MOT)
so I was considering the aldl interface you do (if you still have one) to investigate the issue. thanks.
If I can't fix it - - it don't get fixed!!!
scubasteve
Postby clemo » Tue 09.10.2018, 20:32
As a Mac user i and subject to much abuse from Pinky. This also gives him more "told you that they are crap" ammo.
That said i could probably buy some kak old phone to get me in the LEC bluetooth Elanscan world .
So as per usual i would like to acquire said item fashionably late ( or did you have an plug in thing for the very old MK1 version that timmo only returned to me once his ZX81 computer died !.)
Ta .
clemo
Return to ElanScan
