ElanScan Interface
Re: ElanScan Interface
Postby brian s » Thu 24.06.2010, 20:31
hi geoff,
cable arrived on saturday,thanks
brian s
Postby GeoffSmith » Mon 12.07.2010, 21:32
Sorry, but all sold out for the time being.
Postby scogger » Tue 20.07.2010, 20:36
GeoffSmith wrote:Sorry, but all sold out for the time being.
Hi Geoff, I will be intrested in one, when do you think you'll get some more?
Clive
scogger
Postby Steve A » Tue 20.07.2010, 22:10
:D I've got one but never used it USB version, now I'm all Mac so don't think I ever will :?
Postby scogger » Tue 20.07.2010, 22:17
Steve A wrote::D I've got one but never used it USB version, now I'm all Mac so don't think I ever will :?
steve
if going spare, i'll purchase it from you.
:D
Clive
scogger
Postby rip » Wed 21.07.2010, 08:35
Don't the latest Macs run on an Intel chip so you can dual boot?
If not, there's virtual PC.
Postby Alan_C » Wed 21.07.2010, 16:37
I've got a tiny and very smart netbook, a Sumsung NC10. Runs Windows XP and has USB ports, very compact to run ElanScan on and the battery lasts for hours and hours. Not expensive either, as PC/laptops go.
Alan_C
Postby saska » Wed 21.07.2010, 19:44
Alan_C wrote:I've got a tiny and very smart netbook, a Sumsung NC10. Runs Windows XP and has USB ports, very compact to run ElanScan on and the battery lasts for hours and hours. Not expensive either, as PC/laptops go.
Very good machine - got to love the Atom processors. I setup & configured one for a lawyer and then did about 25 more in short order after she went to a conference -- at one stage had a queue of the buggers in my workshop.
I'd also thought one of the NC10s would make a great on board computer in an Elan for media centre, GPS nav, elanscan, etc. Problem is where you'd put a touch screen without losing a std 1 din unit and the centre vents...
Tony
adw (at) saska.co.uk
saska
Postby dapinky » Wed 21.07.2010, 21:38
saska wrote:I'd also thought one of the NC10s would make a great on board computer in an Elan for media centre, GPS nav, elanscan, etc. Problem is where you'd put a touch screen without losing a std 1 din unit and the centre vents...
Angie has recently replaced her IBM laptop with a Samsung N130 netbook and loves it (probably because it's pink :roll: ).
Last year i looked into a 'built in' carputer using my old IBM T30 onto a permanently wired docking station in the boot/hood tray, so i could have it set as a datalogger on elanscan, media player, satnav and interweb etc..... never got too far past the planning stage, mainly due to the head unit (i was looking at a single DIN unit with a flip-up screen) but remain unsure if it would obscure the vents too much :?
May be time to re-consider with a netbook .......... now they are getting more affordable, with solid state memory and good battery life, it could become a whole lot easier/more reliable........
Postby GeoffSmith » Wed 21.07.2010, 22:13
Steve A wrote:I've got one but never used it USB version, now I'm all Mac so don't think I ever will :?
Steve, the interface drivers support MacOS and even if you can't run ElanScan in virtual PC or with dual boot (I've got the youngest looking at it now as he has a Mac) then I have almost cloned ElanScan in LabVIEW and I believe it can be compiled for Macs.
I have some built up but no ALDL plugs - I need to order some tomorrow as someone else is after one.
load of old codgers wrote:Rhubarb, rhubarb, notebook, netbook, pinkbook....
Bugger off......
Postby Steve A » Wed 21.07.2010, 23:32
If you can sort it for the Mac that would be great
let me know if you do, I'll keep hold of my cable
for now just in case :wink:
Postby GeoffSmith » Thu 22.07.2010, 00:46
Found a cheaper source - ordered tonight and hopefully in by the weekend.
Postby trevorc » Fri 23.07.2010, 17:44
Geoff.
I'd like too please. Will I be able to use with my Carlton also?
T.
trevorc
Postby GeoffSmith » Fri 23.07.2010, 19:32
Plugs are in Paris so maybe not this weekend. If anyone else wants one, please shout now so I can order up the hardware and build them all in one batch.
Scogger - do you want one or are you going to wait to see if the MacElanScan project fails to materialise?
TrevorC - Is it a Lotus or Vauxhall Carlton? You won't be able to use ElanScan on either but I've had a quick check and found some information on the Lotus who refer to Autobahnstormers who may have GM information, so there is probably a CarltonScan or similar available. The only other question is what does the Carlton ALDL plug look like? If it's the same as the Elan then all well and good but if it is different, I can try and source one and give you a plugable option.
Postby trevorc » Fri 23.07.2010, 20:37
Geoff.
Many thanks for this. My (other ) car is a Lotus CArlton and, yes, the ALDL looks the same.
If you are making up a batch of M100/Elanscan cables, then yes please. Code14 on my S2(no 066) is driving me barmy at the moment. I'll then have a wire to connect the Carlton to a laptop and I can then speak to the Autobarnstormer boys about some software.
T
trevorc
Postby scogger » Wed 28.07.2010, 15:10
[quote="GeoffSmith"]Scogger - do you want one or are you going to wait to see if the MacElanScan project fails to materialise?
Hi Geoff,
Yes, I still want one.
brds
Clive.
Clive
scogger
Postby Andy_J » Wed 28.07.2010, 22:11
Hi Geoff
I could do with an elan sacn USB cable or the converter for the serial cable (I have an old serial cable)
Andy
90H BRG SE 48,000 Miles
Andy_J
Postby GeoffSmith » Wed 28.07.2010, 22:18
Did you asked me this before Andy or was it someone else? :oops:
I should have USB interfaces by the weekend and I have a spare USB to serial converter (although Dermot had problems with his so I wanted to try it out before sending it out). Do you want me to put one in with the manifold? :wink:
Postby Jackonicko » Wed 28.07.2010, 23:49
If a big hairy man rushes up and kisses you..........
Jackonicko
Postby abmunro » Thu 29.07.2010, 08:43
I guess my Elanscan is no good to me now as I have fitted Haltech...
I'm keeping old ecu so it can be made origonal on my DEATH ( I intend keeping the car )
But if anyone wants to borrow mine, It is available.
Tony
abmunro
Return to ElanScan
